Author Topic: Modifying Model M rubber dome keycaps to buckling spring  (Read 1709 times)
Offline xwhatsit
« on: Mon, 27 June 2011, 04:16:38 »
Has anybody ever done this?
Got my keycap order from acfrazier today; I ordered a full set of black keys as part of it. Everything was sweet except the spacebar is a rubber dome (`Quiet Touch') spacebar (the protrusion on the bottom is filled in, there's no recess for a spring).
Normally I'd order another but I'm a bit far from Merika and the shipping makes it a pain.
Did anybody ever grind/clip/stab out the middle bit for use on a buckling spring board?
Beam spring IBM 5251 (7361073/7362149) & IBM 3727 (5641316) | Model F IBM 122-key terminal & IBM PC-AT 84-key | Model M Unicomp 122-key terminal | Cherry MX Blue Leopold Tenkeyless
