Author Topic: Which tenkeyless+trackpoint IBM keyboard is this?  (Read 2214 times)
Offline TacticalCoder
« on: Mon, 27 June 2011, 10:33:01 »
I guess this is some rubber dome crap?
woody
  •  Guest
« Reply #1 on: Mon, 27 June 2011, 10:38:43 »
IBM Space Saver II.
Rubber dome, don't know about how good it is - never had one.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Mon, 27 June 2011, 10:48:50 »
Average rubber dome.  Have one at work on the crash cart.
Filco w/ Imsto thick PBT
Offline The Solutor
« Reply #3 on: Mon, 27 June 2011, 11:10:57 »
Quote from: TacticalCoder;368859
IBM keyboards are hardly crap, no matter the technology used.
« Reply #4 on: Mon, 27 June 2011, 11:24:30 »
Quote from: The Solutor;368877
Are them Space Saver II worth anything?
Offline The Solutor
« Reply #5 on: Mon, 27 June 2011, 11:36:42 »
Quote from: TacticalCoder;368884
Usually they are used as input devices for PCs...
Jokes aside, too much time since I touched one of them, but really I can't remember a single IBM/Unicomp/Lenovo keyboard that I would define crap.
They are usually in the range, good - very very good
Offline Pylon
« Reply #6 on: Mon, 27 June 2011, 14:56:50 »
It's an NMB so I'm guessing it should be fairly decent. IBM's other rubber dome boards aren't half bad either. I have a Rapid Acess II KB-9930 sitting in front of me and it's a little better than average.
