Author Topic: DSI Modular Mac Cherry Brown Mechanical Numpads $29  (Read 2889 times)
Offline REVENGE
« on: Thu, 30 June 2011, 02:49:21 »
http://cgi.ebay.com/Mechanical-Number-Pad-Keypad-Brown-Switch-for-Mac_W0QQitemZ400101801779
DSI Cherry Brown numpads. I don't particularly like the layout for a pure numpad, and the ultrashort cable would need to be extended in most setups. However, being a DSI it might have NKRO, and this Brown version is the cheapest NIB mechanical numpad I could find at the moment.
Offline Ascaii
« Reply #1 on: Thu, 30 June 2011, 03:50:00 »
deal killer: NOT COMPATIBLE WITH: Windows PC's
Offline REVENGE
« Reply #2 on: Thu, 30 June 2011, 04:37:31 »
Quote from: Ascaii;370473
Does this have something to do with DSI's NKRO over USB implementation issues? Because otherwise I see no reason why this would be true. Maybe they changed controllers during a second revision, because these keypads are listed everywhere else as compatible with PCs.
Offline Ascaii
« Reply #3 on: Thu, 30 June 2011, 04:57:12 »
from what i hear these will only run if connected to their modular keyboard unit, has anyone actually tested these seperately from the MAC modular keyboard?
Offline dreamingftw
« Reply #4 on: Thu, 30 June 2011, 23:10:22 »
Deal killer indeed... in need for a mech keypad at a good price...
Offline mmmty
  • bang! bang!
« Reply #5 on: Thu, 30 June 2011, 23:47:17 »
I didn't think I needed one until today. I might get one for my Mac.
Just bought one of this. Don't know if it will work with Mac but should work with Windows. Still need to get a serial to USB adapter for it.
http://cgi.ebay.com/Alps-Serial-IBM-PC-Tactile-Numeric-Keypad-NIB-/290575509195?pt=LH_DefaultDomain_0&hash=item43a7a666cb#ht_500wt_844
« Last Edit: Thu, 30 June 2011, 23:52:04 by mmmty »
Keyboardless
