Author Topic: chattering caps lock key on unicomp spacesaver  (Read 1821 times)
Offline sam113101
« on: Fri, 01 July 2011, 18:02:42 »
How do I fix it*?
Hoping to hear from you again, your dearest friend, sam113101.
Offline ch_123
« Reply #1 on: Fri, 01 July 2011, 18:47:59 »
First off, try removing the keycap and reinserting. Also, check for any popped rivets around the area on the underside.
Offline sam113101
« Reply #2 on: Fri, 01 July 2011, 19:02:26 »
How do I remove it without breaking anything*? Is there a stabilizer*?
Offline ch_123
« Reply #3 on: Fri, 01 July 2011, 19:07:38 »
Blunt knife or flathead screwdriver.
There's no stabilizer. When reinsering the key, it helps to hold up the front of the keyboard so that the buckling spring lies against the top of its housing.
Offline noodles256
  • le legendary
« Reply #4 on: Fri, 01 July 2011, 19:29:47 »
ping
AF | Ducky YOTD |
Offline ch_123
« Reply #5 on: Fri, 01 July 2011, 21:00:15 »
Aren't you the guy that's meant to welcome everyone to Geekhack?
Offline keyboardlover
« Reply #6 on: Fri, 01 July 2011, 21:12:59 »
This is why we need troll polls.
Ping!
