Author Topic: Recommend Me a Board  (Read 2126 times)
Offline Mr.Zergling
« on: Fri, 01 July 2011, 21:23:12 »
So, I have a $125 (USD) budget, and am set on a board with blues, and is tenkeyless. I was thinking about ordering a Leopold from EliteKeyboards, but I don't really want to wait until the 14th (but I will if I have to). I was thinking about a choc mini, but I've heard there might be build issues and that they're kinda uncomfortable for those of us with large hands.
So, any other options?
EDIT: at least 6kro is required too
« Last Edit: Fri, 01 July 2011, 21:30:18 by Mr.Zergling »
Offline noodles256
  • le legendary
« Reply #1 on: Fri, 01 July 2011, 21:46:36 »
does it need to be a mechanical board? word on the street logitech is best keyboard brand.
AF | Ducky YOTD |
Offline Chobopants
« Reply #2 on: Fri, 01 July 2011, 21:47:28 »
If it's a tight budget and you can't squeeze 20 more bucks for a Filco the Leopold is a great option for you.
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline Astounding
« Reply #3 on: Fri, 01 July 2011, 21:59:51 »
Go with the filco, or a ducky.
Offline reaper
« Reply #4 on: Fri, 01 July 2011, 22:05:18 »
Well, qtan told me that Ducky tenkeyless (1087) is out of stock everywhere.  Spend a little more and go with a Filco.  That's what I would do anyway.
Din Eli
Offline mmmty
  • bang! bang!
« Reply #5 on: Fri, 01 July 2011, 22:20:13 »
Get 10 Logitech keyboards. This way you have a keyboard on every desk and have backups in case one failed.
J/K, just get a Filco tenkeyless - end of story.
Keyboardless
Offline Mr.Zergling
« Reply #6 on: Fri, 01 July 2011, 22:22:57 »
Not sure if I have to pay tax on the filco, I live in Washington (state) so I have to pay nearly 10% sales tax on everything I buy from amazon Q_Q.
Edit: but of course, all the filcos with blues are out of stock there as well........Might as well just wait for the leos at this point
« Last Edit: Fri, 01 July 2011, 22:35:17 by Mr.Zergling »
Offline Mr.Zergling
« Reply #7 on: Fri, 01 July 2011, 23:28:17 »
On further reflection, I think I might just grab a choc mini here: http://cgi.ebay.com/Noppoo-Choc-Mini-84-Mechanical-Cherry-MX-Blue-keyboard-/120738959835?_trksid=p5197.m7&_trkparms=algo%3DLVI%26itu%3DUCI%26otn%3D4%26po%3DLVI%26ps%3D63%26clkid%3D1049784206875798568#ht_2306wt_1139 I am a fan of small layouts, as I will be toting the board between home and school, and nkey over USB is pretty nice too (I never use macs) Anything I should know about the choc mini before I pull the trigger?
Offline reaper
« Reply #8 on: Fri, 01 July 2011, 23:39:18 »
^ Why don't you buy it from qtan's thread?  He has the Choc Mini blue listed for $76.22.
Din Eli
Offline Astounding
« Reply #9 on: Sat, 02 July 2011, 00:29:24 »
The filco is a bit more than a little more at double the price, can the feel really be that much better?
Offline Mr.Zergling
« Reply #10 on: Sat, 02 July 2011, 00:33:13 »
Just realized I should wait for the Leos, just because of warranty.
Thanks everyone.
