Author Topic: Red will be the new brown  (Read 35852 times)
Offline elitekeyboards
  • * Commercial Vendor
    • http://elitekeyboards.com
« Reply #150 on: Wed, 06 July 2011, 05:27:30 »
Quote from: sordna;373291
So to get things back on topic, do you believe the red switch will become more of a standard in the near future, and offered at the same price as the rest types of switches? Hopefuly elitekeyboards can provide some perspective on this!
You'll see more reds in the near future, from multiple companies no doubt, but if anyone is charging a significantly larger amount over other switches on the same model board (retail), then you should give them the stink-eye. There is a price difference between the different switches, but it is a small % difference at bulk cost; so even if a reseller has a standard mark-up %, the price difference would only end up being a few bucks...a $50 premium is excessive.
Offline sordna
« Reply #151 on: Wed, 06 July 2011, 09:15:12 »
Thanks for the input... and thanks for bearing with us, it's been a little rough around here lately, bug getting much better again.
Anyway, choice of switches is a good thing, I'm glad we have lots to choose from!
Offline Input Nirvana
« Reply #152 on: Wed, 06 July 2011, 09:37:56 »
Supply vs. Demand
Economic principles at work.
Offline csm725
  • I BLEED RED AND GOLD
    • http://csm725.com
« Reply #153 on: Thu, 14 July 2011, 02:19:09 »
Looking at getting the second round of OCN Duckys when it's out:
10keyless MX Reds with set of PBT Engraved caps.
How is Ducky's build quality?
Offline Trueepower
« Reply #154 on: Thu, 14 July 2011, 02:45:34 »
I've tried a blue switch board, black, and red. I think the red switch is the best so far. Although, I can see the positives of the other switches. Next I will be trying the Topre switch. It will be interesting if the Topre will be better than the red cherry switch.
Topre Realforce 87ub 55g Topre Realforce 87ub 45g
Luxeed MK5
Offline pm_
« Reply #155 on: Thu, 14 July 2011, 03:01:30 »
A friend of mine got a PLU with red switches, and I tried it very briefly today.  The reds definitely feel lighter than the browns, but not substantially so.  The relative light feel of the red switch may be partially attributable to the lack of a tactile bump, but I don't really notice the missing bump that much as I feel a difference in activation force.  The red is definitely a decent switch, but probably too light for my taste, although fairly close in feel to browns. It is much better than though black switches though, which I hate due to their high activation force.
A little OT for the thread, but I was at his place to temporarily swap brown switch keyboards: my Leo for his Ducky.  It's odd, but I definitely feel a difference, with the Ducky feeling bouncier and more responsive. It could be that my Leo is broken in, and his Ducky has hardly been used, as he tends to use blues and an IBM Space Saver most of the time.  I'll be using his Ducky for at least a month, so we'll have to compare at that time and see if they feel more similar.  Also, no squeaking stabilizers with the Ducky!  I guess the point here is that your red switches may end up feeling different in different model keyboards, as well as new vs. broken in.
« Last Edit: Thu, 14 July 2011, 03:04:25 by pm_ »
