Author Topic: Does a UK / ISO keyboard layout exist which has a long shift key?  (Read 4994 times)
Offline pac-man
    • http://pchristou.com/
Good Morning GH,
I'm really keen on getting a uk Filco tenkeyless brown switch kb. I want the keyboard to be UK layout one reason being, I'm use to the @ being near the enter key. However, my one issue with ISO is the short shift key. Does some sort of hybrid kb layout exist for the Filco?
Thanks,
P
Offline ch_123
« Reply #1 on: Mon, 04 July 2011, 02:43:27 »
No. Besides, if such a thing existed, you'd have to accomodate the \| key in some other place, which would be messy.
Id suggest getting the ANSI board, and making a custom key mapping on the OS, or even just getting used to the location of @
« Last Edit: Mon, 04 July 2011, 02:46:31 by ch_123 »
Offline Zhuni
« Reply #2 on: Mon, 04 July 2011, 07:11:45 »
I switched to ANSI (UK person here) and much prefer it for general typing and gaming. There's not a whole lot of difference and you'll get used to it really fast.
[sigpic] [/sigpic]
KBC Poker
Offline The Solutor
« Reply #3 on: Mon, 04 July 2011, 09:48:04 »
Quote from: pac-man;372934
Good Morning GH,
Thanks,
P
Look at 6gv2, it has a big enter, big backspace and big left shift, swap the keycaps with an UK set (or with the UK stickers), and map the 105th key to alt gr+something
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #4 on: Mon, 04 July 2011, 11:00:02 »
The closest I could find is a UK layout tenkeyless with blues. You could try PMing them and ask whether they'll get in ones with browns any time soon.
