Author Topic: Textured vs. Smooth keycaps.  (Read 9052 times)
Offline Wibox
« on: Wed, 06 July 2011, 23:59:35 »
It looks like most older keyboards have smooth and shiny keycaps, while modern keycaps are usually textured to some degree (matte finish). I've never used a keyboard with completely smooth keycaps, so I'm curious to know how the difference in feel is.
Anyone here have experience with both?
Picture of my current favorite keycap picture, with smooth keys:.
And here is my KBC PBT keycaps, with texture:
!! YKBDS !! - KBC Poker (Ergo Clear Cherry) - Apple M0116 (Pink ALPS) - Apple M0115 (Orange ALPS) - Das Keyboard (Blue Cherry) - IBM Model F - IBM Model M - Dell AT101W (White ALPS) - Cherry POS 8000 (Clear Cherry) - Apple Extended II (Cream ALPS)
Offline theferenc
« Reply #1 on: Thu, 07 July 2011, 00:03:00 »
There's definitely a difference between worn smooth, and designed smooth. I've used some designed smooth spherical key caps, and they are pretty nice, honestly. Have a totally different feel to them, both because of the texture and the shape. I don't think I would like the smoothness on cylindrical key caps though.
They were always much colder, if that makes any sense. I have no idea why, but they were. Nicely cool, is how I would describe them. But they get slick kinda fast after using them for a while if you develop any sweat or moisture on your hands.
Offline mr_a500
« Reply #2 on: Thu, 07 July 2011, 02:51:53 »
 :blank:
« Last Edit: Wed, 04 July 2018, 09:57:58 by mr_a500 »
« Reply #3 on: Thu, 07 July 2011, 04:23:57 »
The material matters also. A key cap that is worn until it is shiny, but made of the right material still provides more friction against your finger than a new textured cap made of the wrong material.
Re: Textured vs. Smooth keycaps.
« Reply #4 on: Fri, 06 February 2015, 19:33:44 »
Smooth
Offline jonathanyu
« Reply #5 on: Fri, 06 February 2015, 20:08:27 »
so many necro posts today...
Offline jacobolus
« Reply #6 on: Fri, 06 February 2015, 20:46:14 »
My favourites for keycap feel are the TRS-80 Model III (fine granular, like hardened rubber) and the early TI-99/4a (frosty, but with a chalky feel I've never felt on another keyboard).
If you’re still around, which versions? Each of these had multiple different types of keyboards for it, with different switches and keycaps.
Also, yeah, 3.5 years is pretty long for a thread to sit before being dug back up. Pretty sure there have been more recent threads on this topic.
« Last Edit: Fri, 06 February 2015, 20:47:50 by jacobolus »
« Reply #7 on: Fri, 06 February 2015, 22:11:48 »
How do people find these old threads?
And what prompts them to reply to the thread, knowing that in most cases the OP has long since departed GH?
« Reply #8 on: Sat, 07 February 2015, 02:17:28 »
I was prompted to do this by SpAmRaY, it's all his fault.
« Reply #9 on: Sat, 07 February 2015, 02:43:13 »
