Author Topic: KBC PBT keycaps  (Read 18646 times)
Offline Polaris
KBC PBT keycaps
« on: Sat, 09 July 2011, 22:18:26 »
so about a month ago I received the "gold" on black pbt caps
after about a month of moderate use, the lettering on the wasd keys is already fading, which i am quite frustrated about. i was pretty anal about keeping my hands clean before using the kb everytime and using the plastic cover from my filco when the kb wasnt in use
just wondering if anyone that had bought the "grey" on white pbt caps have shared the same issue?
i thought i had read somewhere that they were done differently
looks like i might have to look into the engraved caps, too bad the white ones are all gone. anyone wanna sell me a set?:P
Offline theferenc
KBC PBT keycaps
« Reply #1 on: Sun, 10 July 2011, 22:27:28 »
Black keycaps are usually pad printed, which is less durable. It's likely the white ones are either lasered or dye subbed, both of which often last longer.
It's possible the black are infilled lasered keycaps, but those also exhibit wear fairly quickly.
Offline himynameisbunny
KBC PBT keycaps
« Reply #2 on: Mon, 11 July 2011, 00:44:15 »
How would clear nail varnish work on the infilled laser keys?
Should totally put that inside the lasered bit, the filling certainly wouldn't come out then.
[SIGPIC][/SIGPIC]
Happy Hacking Keyboard Pro 2 // Logitech M570 Trackball // Topre Realforce 23UB
Offline Polaris
KBC PBT keycaps
« Reply #3 on: Mon, 11 July 2011, 17:39:55 »
ah ok, thanks for the info
guess the "grey" on white keycaps were lasered then. need to pick up a set when imsto restocks them
Offline Chobopants
KBC PBT keycaps
« Reply #4 on: Tue, 12 July 2011, 09:12:47 »
Yeah, after a couple months of pretty heavy use there is no visible wear on the grey/white keys at all. They're a bit dirty looking, though.
Realforce 87UW 45g - Filco Blue 87 - Filco Linear R - Filco Brown 104
Offline daerid
    • Rossipedia
KBC PBT keycaps
« Reply #5 on: Mon, 18 July 2011, 01:36:26 »
^^^ I have the same sets that Chobo does. I wash my hands religiously before using my boards, so mine are still in pretty mint condition.
