Author Topic: Before I steal a keyboard from the throw away pile at work...  (Read 1934 times)
Offline Pixel_Outlaw
I'd like to know if it is compatable with Windows and modern ps/2 standard.
There is a terminal keyboard at work of IBM make that is from an AS/400 server.
It has a MIDI looking plug but instead of having the 5 pins closely spaced they are spread out with about 60 degrees between each one.
Is this bad boy worth taking home with the bosses permission?
It is mint looks like the server was well respected...
This is the plug end I believe...
http://en.wikipedia.org/wiki/File:DIN-5c_Diagram.svg
Brown and black are the colors of cowardice. May my springs shake the heavens!
Offline DaemonRaccoon
« Reply #1 on: Mon, 18 July 2011, 18:37:42 »
Terminal? Sounds like you'll need to build a converter, like this one. I'm sure someone else will be of more help.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
« Reply #2 on: Mon, 18 July 2011, 18:42:11 »
Yes 122 key terminal.
Ah, I see.
I was hoping for an off the shelf solution but if I have to go cutting and soldering then I might give it a try.
Offline Hydroid
    • http://justin.tv/hydr0id
« Reply #3 on: Mon, 18 July 2011, 19:10:06 »
I'd say try get permission regardless. If it ends up not working out you could salvage parts for a future project or something.
Intel Core i7 870 @ 2.93GHz | Corsair H50 | 16GB G.Skill DDR3 | Asus P7P55D-E Pro | Galaxy nVidia GeForce GTX 460 SLI
OCZ 60GB SSD | 2x 1TB Seagate Barracuda RAID-0 | Samsung Blu-Ray Burner | Corsair HX-850W | 2x BenQ G2420HD 24"
Leopold FC200R Tenkeyless Blue | Ducky DK9008(B) Blue | Qsenn DT-35 Black PS/2 Rubber Dome |2x Razer Lycosa USB | Microsoft 500 PS/2
Help me support and grow e-sports below!!!
What Happens in Starcraft -- Vlogs -- Twitter
Offline Touch_It
« Reply #4 on: Mon, 18 July 2011, 19:12:52 »
Quote from: Hydroid;382925
and terminal boards are just bad ass
« Reply #5 on: Mon, 18 July 2011, 19:17:33 »
It just may be the model shown here, I was in a hurry plowing through the back room and didn't want people to think I was stealing anything.
http://www.seasip.info/VintagePC/ibm_1390876.html
Offline Touch_It
« Reply #6 on: Mon, 18 July 2011, 19:40:31 »
so so sexy
Offline Mr. Perfect
« Reply #7 on: Mon, 18 July 2011, 20:19:40 »
Quote from: Pixel_Outlaw;382936
This is kind of off topic here, but plowing through in a hurry is exactly what will make people think you're stealing things. Anyone who has a genuine reason for doing something won't be in a frenzy. Heck, they'll probably be kind of bored and moving slowly.
If you have a terminal Model M( or F!) you can certainly sell it here if you don't end up liking it.
Mr. Perfect - A name fraught with peril.
G80-8113HRBUS MX Clears, FC200R MX Clears, RK-9000v2 MX Blues.
