Author Topic: Filco Papillon is this a novelty ?  (Read 1765 times)
Offline The Solutor
« on: Fri, 22 July 2011, 17:18:24 »
I never heard about it...
http://www.diatec.co.jp/en/det.php?prod_c=517
Maibe they listened what I said and started to do some innovation ?
Offline cirE
« Reply #1 on: Fri, 22 July 2011, 17:41:54 »
It's just rubber domes.
Source
FKBN87MC/EB w/ FKBPRM/B
Offline The Solutor
« Reply #2 on: Fri, 22 July 2011, 17:44:20 »
ok, danke.
I tough was mechanical because listed with the majestouch...
