Author Topic: Filco - 1 Jug of water - 0  (Read 2769 times)
Offline skyblue
« on: Mon, 25 July 2011, 20:37:06 »
Accidentally hit a jug of water I had near the computer and BOOM - water everywhere, especially on my 104 MJ2. Quickly unplugged it, sprayed it dry with some compressed air and still working perfectly.
My face after plugging it back in:
Das Professional S | Filco Majestouch-2 104
Offline Tony
« Reply #1 on: Mon, 25 July 2011, 20:56:18 »
Hmm, next time you may not be so lucky.
Offline REVENGE
« Reply #2 on: Mon, 25 July 2011, 20:58:46 »
Yay, someone does the right thing and dries it before powering it on. Good for you!
Offline Arcanius
  • Buckling Spring Lover
« Reply #3 on: Mon, 25 July 2011, 21:11:20 »
How long did you wait for it to dry? Don't want any left over water seeping into the switches or the controller.
Offline skyblue
« Reply #4 on: Mon, 25 July 2011, 22:01:16 »
Quote from: Arcanius;387132
True, I only waited about 10 mins tops after blowing everything out. Hopefully that's enough.. no problems so far.
Offline jumpfroggy
« Reply #5 on: Tue, 26 July 2011, 00:16:06 »
Quote from: skyblue;387167
That's not nearly enough.  It's good to drain water, and to unplug.  But there's definitely moisture still in the switches after 10 minutes.  Probably true after 24 hours as well.  I'd definitely recommend putting the keyboard in a bag with rice or other dessicants when you're not using it.  Likely the electronics are fine, but you wont know until later if the contacts/wires/springs are rusting.
But yeah, you dodged a bullet.  Good job!  Now keep that jug of water further away :)
Filco FKB104/EB - Das Keyboard Ultimate S - Realforce 103UB variable - Filco Linear-R (soon)
Offline bpiphany
« Reply #6 on: Tue, 26 July 2011, 01:49:16 »
Really, on a keyboard without any fancy gadgets built into it, like the Filcos, the only thing that should be bad to shortcircuit is the controller itself. Everything else is sort of designed to be shortcircuited =P This should make keyboards sort of tough to kill that way. I don't say it is the case only that I would be disappointed if it killed one. Pouring liquids into them could have other nasty effects though (corrosion, stickiness, smell, mold, I-dont-know-what).
Offline skyblue
« Reply #7 on: Tue, 26 July 2011, 02:54:31 »
Quote from: jumpfroggy;387253
Thanks for the tip, I'll throw it into a bag of rice tomorrow. I may have spoke too soon, the backsapce is starting to act kind of buggy. booo
Offline Tony
« Reply #8 on: Tue, 26 July 2011, 05:35:59 »
Jug of water started to counter-attack.
Offline jumpfroggy
« Reply #9 on: Tue, 26 July 2011, 10:14:06 »
Quote from: skyblue;387310
Yeah.  There's two dangers - the immediate shorting, which is bad but generally you can avoid if you unplug quickly.  But then the water is trapped in there and does not evaporate quickly, so you get secondary damage.
Yes, I've had a lot of experience with water-damaged electronics.  I've actually washed an iphone in the washing machine, full cycle.  I wrapped it in a towel, sent it through the dryer a few times, and it worked just fine - even the LCD.  That was pretty surprising.
You just want to dry that thing out well.  I'd actually recommend using one of those "sneaker" drying racks in the dryer (if you have one), and putting it through there a few times.  The sneaker rack holds the item in the middle of the dryer w/o letting it tumble around.  Without that, rice & other desiccants are good.
Offline Bry
« Reply #10 on: Tue, 26 July 2011, 10:51:14 »
If you can, just disassemble the case so that the guts are exposed and let it dry out overnight. I dunno if I have the balls to put a keyboard in the dryer though lmao
last.fm | deviantART | SC2
Filco MJ2 Ninja - MX Red | Filco MJ2 Ninja - MX Brown | U9BLS - MX Brown
Offline jumpfroggy
« Reply #11 on: Tue, 26 July 2011, 11:36:14 »
Quote from: ripster;387499
I DataVac'd my opened up Sansa Clip after it fell in the toilet bowl while peeing.  Works fine.  But lost some of it's panache.
"Do you love peeing, but *hate* the boredom?  Introducing ripsterco's new (mostly) waterproof mp3 player!  Boring time?  FUN DANCE TIME!*"
*NOTE: ripsterco is not responsible for any injuries incurred due to excess dancing while using ripsterco's (mostly) waterproof mp3 player.  Do not attempt to eat any part of the media player.  If you experience headaches, dizziness, oily stool, or complete loss of aim while using the media player, please discontinue use and consider adult diapers.  Ripsterco's media player is not a toy.  Any implied guarantee of fun or improved quality of life is merely incidental, and represents no contract on part of ripsterco or it's parent company TOTALLY NOT DANGEROUS TOYS, INC.  Please wash your media player often."
