Author Topic: Custom CNC Case for HHKB Pro 2  (Read 8109 times)
Offline Index
« on: Sun, 31 July 2011, 01:05:10 »
Hi all,
I just received my HHKB Pro 2 (dark grey, w/ printed keycaps) about 3 days ago. I love this keyboard. The one thing that bothers me is that it doesn't seem very durable. So, I was wondering if a CNC milled case for the HHKB Pro 2 would be a good idea.
Basically, the entire case would be replaced. The only thing that would be left over from the original HHKB Pro 2 are:
- PCB
- Microcontroller + USB Hub
- Rubber Domes
- Capacitive Springs
- Plungers
What do you guys think? And if this is a good idea, where would I start?
Gaming Keyboard: Leopold FC200RT/ABN
Work Keyboard: HHKB Pro 2 PD-KB400B
Offline TheProfosist
  • Custom Layouts Only!
« Reply #1 on: Mon, 01 August 2011, 09:03:51 »
i think it would be great (as long as the case was near the same) but i would probably wait until my warranty is up before doing it.
koreans have done one off keyboards... here and here and here
Offline HaveANiceDay
« Reply #2 on: Mon, 01 August 2011, 09:06:19 »
It's not that hard to make one. It's the price that's the deal breaker. Be prepared to pay the same or more just for a CNC milled case as you payed for the HHKB.
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
Offline Index
« Reply #3 on: Mon, 01 August 2011, 11:17:12 »
Assuming im willing to spend around $300 for the case. Would I have to redraw the specifications/dimensions of the case in some sort of modeling program? To me, that seems a bit hard. Or is there an easier way?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #4 on: Mon, 01 August 2011, 11:23:28 »
You would need to either pay someone to create the necessary file(s) or you would need to create them using some form of CAD.  The fun part is that you need the output to get a quote, and frequently you need different output for different shops.
Lots O fun!   However, there are format converters and a good place to start is Google SketchUp.
MeshLab is the free converter I know of.
Filco w/ Imsto thick PBT
Offline noodles256
  • le legendary
« Reply #5 on: Mon, 01 August 2011, 11:34:54 »
new members and their ambitions. goshhh
AF | Ducky YOTD |
Offline Index
« Reply #6 on: Mon, 01 August 2011, 12:45:29 »
My girlfriend is korean.
Offline Index
« Reply #7 on: Mon, 01 August 2011, 13:28:49 »
Doesn't have any experience, and I'll ask her for the recipe.
For the CNC files, anyone know where I should start? Besides, Google.
Offline alaricljs
« Reply #8 on: Mon, 01 August 2011, 13:42:48 »
I would suggest starting by narrowing the field of output formats by finding a couple CNC shops.  If you're doing on-line, emachineshop is a possibility.  They have their own design tool, but they accept other formats as well.
Then figure out the cheapest/easiest way to make output in the format accepted by those shops.
Then start designing.
« Reply #9 on: Mon, 01 August 2011, 14:12:34 »
Sticking to Autocad formats is a safe bet, pretty much all serious shops should accept it.
Offline Index
« Reply #10 on: Mon, 01 August 2011, 14:35:26 »
Oh man, if I have to do the modeling myself, then it's going to take weeks.
I wonder if someone has already done this for the HHKB Pro 2, or perhaps I could contact PFU and see if they can/would supply the files?
Ripster, the HHKB in the picture u submitted, is it a Pro 2?
Offline The Solutor
« Reply #11 on: Mon, 01 August 2011, 15:45:01 »
A solid external with a soft heart...
Looks like the ads of an icecream :happy:
Offline rodya
« Reply #12 on: Mon, 01 August 2011, 17:33:28 »
Quote from: Index;391094
But that's the fun bit!  Even if it takes a long time, you'll have the satisfaction of the learning and experience of doing it yourself.
Offline cactux
  • Topre Knight
« Reply #13 on: Mon, 01 August 2011, 18:46:26 »
You need detail drawings (tolerances, aluminum type, harnesses, screw type, lengths, etc). no Drawings no CNC that simple.
I do not think you are going to find them using google ;-)
Quote from: TheProfosist;390875
Those are completely different boards. Is like comparing a GM truck and a FORD focus. Both are vehicles but 2 different vehicles.
« Last Edit: Mon, 01 August 2011, 18:51:03 by cactux »
[FS]☠ The temple lol ->HERE<-
Offline cactux
  • Topre Knight
« Reply #14 on: Mon, 01 August 2011, 18:49:26 »
those are completely different boards. Is like comparing a GM truck and a FORD focus. Both are vehicles but 2 different vehicles
Offline Index
« Reply #15 on: Mon, 01 August 2011, 19:12:38 »
Well, I guess I have to start doing the design then. This should be a good learning experience.
« Reply #16 on: Mon, 01 August 2011, 20:05:24 »
Quote from: cactux;391236
Not a lot is required to make a custom case. The most important thing is to measure the PCB and see how it's attached to the case. Then build the case around those limits.
Offline Input Nirvana
« Reply #17 on: Mon, 01 August 2011, 20:07:57 »
[ Attachment Invalid Or Does Not Exist ] 22993[/ATTACH]
WOW.
UBER TRICK.
I've thought of having the Kinesis bowl switch mounting plate milled, then use wood key caps and have spider leg wire frame with everything exposed. May look good, may be an abortion.
« Last Edit: Mon, 01 August 2011, 20:11:45 by input nirvana »
Kinesis Advantage cut into 2 halves | RollerMouse Free 2 | Apple Magic Trackpad | Alphagrip | Colemak
Staying in touch via Tapatalk VIP                                        Thanks much, Smallfry
Offline cactux
  • Topre Knight
« Reply #18 on: Mon, 01 August 2011, 22:21:47 »
Quote from: HaveANiceDay;391271
You need good drawing in order to get some quotes and find out which machine shop is capable to do the best job. Without good drawing, you are the only responsible for the end result. Normally the a professional Machine shops  will not provide you a quote if you provide bad drawings (because is a risk for them).
If you or one of your friends own a CNC and you just want to play around and do some try and error you do not need anything ;-)
« Last Edit: Mon, 01 August 2011, 22:24:39 by cactux »
« Reply #19 on: Mon, 01 August 2011, 22:35:10 »
I don't understand what you mean by bad drawings. The file that you output is either valid or a total ****storm, obviously you want to have a valid file that's appropriate for the desired manufacturing process.
Offline cactux
  • Topre Knight
« Reply #20 on: Mon, 01 August 2011, 22:44:53 »
Quote from: HaveANiceDay;391363
The good drawings must have at least: Dimensions, Coherent Set of Tolerances, material, material harnesses, screw thread type,  etc. This is the basic kind of information the most of the drawing must have.
« Last Edit: Tue, 02 August 2011, 02:33:10 by cactux »
Offline skwan
« Reply #21 on: Tue, 02 August 2011, 01:56:41 »
Don't forget the hhkb hg is made of metal too may want to check out the design there, though I seriously have no clue how to get access to one even just so that I can brag about being in the same room as one, I remember pfu was having a open house a few weeks ago to let people test out the topre/ type s, and there was the hg japan there
Offline Rally Man
« Reply #22 on: Tue, 02 August 2011, 08:41:48 »
Quote from: cactux;391376
Not if you go with 3D printing.  I made this for my wife a weeks ago...
Made this for my wife a few weeks ago.  This is made out of silver and I thought it turned out good.  I used Shapeways for the manufacturing.  There's different materials you can chose from if you don't want it out of silver :-p.  But be prepared to pay a bit plus it still will have some ridges like you see on the bracelet, but you could always sand it.  BTW, I used Solidworks to render and submit the file.
« Last Edit: Tue, 02 August 2011, 08:44:50 by Rally Man »
INPUT GEAR
Work: Logitech MX Revolution |
Filco "Hulk" Majestouch-2 Tactile Action NKR
Home: Razer Imperator | Filco "Doraemon" Majestouch-2 Tactile Action NKR
Want:  3DConnexion SpaceMouse Enterprise | Logitech MX Master
