Author Topic: Generic Keyboard Recommendation  (Read 1481 times)
Offline hiturheartx
« on: Mon, 01 August 2011, 04:41:02 »
Hi guys.
I'm looking for a basic/generic USB compliant keyboard. Need some recommended brand/models that fit the following description:
1. Standard US Layout (shift and backspace are rectangular)
2. No special multimedia/internet/macro keys etc. So no drivers are needed as well.
3. Must have a wrist pad on it (optional or permanent is ok)
4. Not compact/slim/"ergonomic"
Appreciate the help!!
« Last Edit: Mon, 01 August 2011, 04:47:03 by hiturheartx »
Offline noodles256
  • le legendary
« Reply #1 on: Mon, 01 August 2011, 06:41:15 »
like
AF | Ducky YOTD |
Offline keyboardlover
« Reply #2 on: Mon, 01 August 2011, 06:55:22 »
There are tons of keyboards that fit such a description. Check out the wiki (link at top of page).
Offline The Solutor
« Reply #3 on: Mon, 01 August 2011, 07:41:22 »
Quote from: hiturheartx;390822
Hi guys.
1,2,4 a ton of options
3 = U9 or U9plus
Offline HaveANiceDay
« Reply #4 on: Mon, 01 August 2011, 09:04:10 »
Since he never said he's looking for a mechanical one, maybe he doesn't want to spend $100+ on it.
Go to a retail shop and tell them your needs.
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
