Author Topic: Quick question about KBC Poker LEDs  (Read 2792 times)
Offline daerid
    • Rossipedia
« on: Mon, 01 August 2011, 10:59:24 »
Do they have to be wired in a certain way? I just modded my Poker Brown to Ergo Clear, and apparently I broke the LEDs (except for Escape Lock, that one still works). It's possible that I didn't do a good enough soldering job (my tip was having a hard time staying tinned), but I just wanted to make sure that it wasn't because I wired them backwards or something like that.
Thx in advance
Offline alaricljs
  • I be WOT'ing all day...
« Reply #1 on: Mon, 01 August 2011, 11:08:25 »
No knowledge of the Poker here, but LEDs themselves are directional.  It's a diode at the core.
Filco w/ Imsto thick PBT
Offline DaemonRaccoon
« Reply #2 on: Mon, 01 August 2011, 11:10:23 »
Either you mounted them backwards or didn't get enough solder on them. Did you mount them with the cathode (flat side) facing right (that's the right way)?
FUN FACT: Cherry MX have an 'A' on the anode side and a '.' on the cathode side.
122-Key Model F 6110345 1985-03-01 | Model M SSK 1391472 1991-01-22 | Rosewill RK-9000 v1 | KBC Poker X | Filco FKBN87M/PWE2
Offline daerid
    • Rossipedia
« Reply #3 on: Mon, 01 August 2011, 17:50:40 »
Quote from: DaemonRaccoon;390937
I figured as much. However, when I pulled the LED's out, both leads were the same length and I couldn't tell them apart. Are you saying that one lead will be flat, and the other round?
Offline REVENGE
« Reply #4 on: Mon, 01 August 2011, 18:58:03 »
Quote from: daerid;391206
You can probably just take a AAA or something and test the leads manually, I can't imagine any damage would occur at those voltage and current levels.
« Reply #5 on: Mon, 01 August 2011, 19:01:17 »
The LED housing/lens (whatever it's called) should have a flat cathode side, unless these are some really cheap Chinese parts.
« Last Edit: Mon, 01 August 2011, 19:03:31 by DaemonRaccoon »
Offline alaricljs
« Reply #6 on: Mon, 01 August 2011, 20:03:01 »
the best battery choice for testing leds is a 3v lithium coin cell like the CR2032 since it fits nicely between the leads.
Offline sordna
« Reply #7 on: Mon, 01 August 2011, 20:06:06 »
I would be scared of frying a chip if I tried that on an LED that's still soldered to the PCB.
Offline daerid
    • Rossipedia
« Reply #8 on: Mon, 01 August 2011, 21:19:53 »
I'm definitely going to pull them out first.
Just a refresher: anode = + and cathode = -
Correct?
« Reply #9 on: Mon, 01 August 2011, 21:20:34 »
Quote from: daerid;391314
Correct?
Correct.
Offline Philth
« Reply #10 on: Mon, 01 August 2011, 21:30:12 »
Why mess with soldering on a PCB-mounted cherry switch? I thought that was one of the advantages to PCB-mounted switches: Easily swapped without having to solder anything:
http://www.youtube.com/watch?v=bLBXxzmuA_Q&feature=related
(Correct me if I'm wrong)
Offline alaricljs
« Reply #11 on: Mon, 01 August 2011, 21:41:21 »
Except that an LED holds down the upper half of the casing if one is mounted in the switch.
Offline daerid
    • Rossipedia
« Reply #12 on: Mon, 01 August 2011, 23:41:56 »
Quote from: alaricljs;391325
This. Normally, switch/stem swapping on a PCB mounted board is no problem, if not for the LEDs :(
Offline The Solutor
« Reply #13 on: Tue, 02 August 2011, 05:50:38 »
Quote from: daerid;390929
Thx in advance
The longer terminal is the anode
the flat side is the cathode
looking inside the led the bigger terminal is the cathode
Use a lithium batterry yo quick test them, like the  2032 installed in most mainboard as backup
Offline Roguemaster8
« Reply #14 on: Fri, 13 April 2012, 09:51:42 »
I just got the same board from daerid in a trade and want to pick up where he left off, are the leads just opposite of where they should be?
Off topic, but the Poker has a lovely ping sound my other keyboards lack ;).
CM Storm Quickfire | Dell Quietkey | Unicomp Ultra Classic | KBC Poker
Offline sordna
« Reply #15 on: Fri, 13 April 2012, 12:41:46 »
LEDs are (light emitting) diodes, so they will only work in one orientation. Don't worry about the anode/cathode terminology, if your board has an LED that doesn't work, swap it around. Sometimes LEDs die of course, it happened on one of my Kinesis Advantage but Kinesis was kind enough to send me a couple for free so I replaced the bad one myself. Anyawy, with a loose LED you can try out the proper orientation by bringing its leads into contact with the proper points on PCB before soldering it (the keyboard must be connected of course, and you must arrange for the LED to be lit up (by hitting caps lock or whatever for the particular LED position in question).
