Author Topic: Square and Compass key  (Read 5668 times)
Offline iMav
  • geekhack creator/founder
« on: Fri, 19 August 2011, 03:04:02 »
Anyone know if this SVG would be doable by SP?? (or is there too much fine detail?)
Offline gilgam
« Reply #1 on: Fri, 19 August 2011, 07:19:49 »
plain color maybe, but the lines are too thin i think, even if some line on soe characters are as thin as these.
It is better to ask them :-)
Realforce 105 FR, HHKB Pro 2 black, 1 Raptor K1 Black Cherry and 1 Raptor K1 Red Cherry , Compag MX 11800  tBrown Cherry, G80-3000 Clear Cherry , G80-1000 Blue Cherry / Ghetto red, Lexmark 1992 SSK Buckling spring, Unicomp 2011 Customizer 102 Buckling spring
and a few rubber dome/scissors keyboards from Apple/Logitech
« Reply #2 on: Fri, 19 August 2011, 07:52:07 »
Bah. Hardcore freemasons donīt use keyboards. They use Kinect and secret handshakes ... :-P
« Last Edit: Fri, 19 August 2011, 15:07:19 by Findecanor »
Offline the_buff
« Reply #3 on: Fri, 19 August 2011, 09:42:45 »
Now it makes sense, they run world AND this website.
I heard from 7_bit that the lines must be at least 0.2mm thick with the gaps between each line at least 0.5mm thick.
Also, the graphic can only be 9.04mm wide and 10.84mm tall, or vice-versa--I'm not sure.
If no one has opened your SVG in a vector graphics editor and measured it by this evening then I'll take a look.
Offline the_buff
« Reply #4 on: Sat, 20 August 2011, 00:47:10 »
Well, if you scale it down proportionally it should work.  The measuring ticks are about 0.6mm apart, but a few would have to go.  Also, not sure if the angles would end up sharp or be sort of rounded.  I'll post the shrunken version tomorrow so you can see for yourself.
Offline aggiejy
« Reply #5 on: Mon, 22 August 2011, 17:04:06 »
Sounds like you got the answer, but just to follow up:
[ Attachment Invalid Or Does Not Exist ] 24872[/ATTACH]
Left is your original (at the keycap size) and right is (quickly) adjusted to their min line thickness of 0.012".  But as you can see, your islands are smaller than the 0.020" min island thickness in several places, most notably around the G.  You could simplify it more and get close, but it's a crapshoot on how clean they'll be able to keep the plastic.  The edges, corners, and lines will look good I'd guess, but you certainly don't want the G bleeding into the lines.  And it's hard to make it much smaller without collapsing on itself.
« Last Edit: Mon, 22 August 2011, 17:08:32 by aggiejy »
Offline the_buff
« Reply #6 on: Mon, 22 August 2011, 17:18:57 »
Thanks aggiejy, I got sidetracked.
Offline Izza
« Reply #7 on: Wed, 31 August 2011, 23:35:02 »
Could we possibly add a Moose Lodge key to this?
[SIGPIC][/SIGPIC]
