Author Topic: MX8100 optimum paper size under clear caps  (Read 5797 times)
Offline pex
« on: Wed, 24 August 2011, 04:13:22 »
I've got a Cherry MX8100 style keyboard.  Does anyone know the specification for paper inserts that go under the clear caps?
⌨Ж®Cherry G80-8113 (someday I hope to have one that reads magstripes, rfid cards, and smartcards), ⌨broken \'98 42H1292 Model M, ⌨some other Model M from a decade before that, ⌨30 more keyboards in a box, ⌨4 more lying here or there
Destroying Sanctity: my Model M project. Status: Dead.
Offline N8N
« Reply #1 on: Wed, 24 August 2011, 05:57:14 »
I already made a file in AutoCAD (and then saved it as a .pdf) of the labels for a MX8000 which uses the same relegendable keys.  Unfortunately my web site is no longer up, but PM if you want me to send it.
Offline N8N
« Reply #2 on: Wed, 24 August 2011, 08:58:29 »
I just looked at the file that I'd put together and the dims of the labels that I made are 13/32" wide by 1/2" high.  they look pretty good.
good luck
