Author Topic: Kinesis and replacement keys.  (Read 1398 times)
fossala
  •  Guest
« on: Sat, 27 August 2011, 03:56:38 »
On the kinesis it looks like the capslock key is a 1.25 key? Is this correct so I could remap it ctl or alt and then just put on a normal alt or ctl key?
Thanks.
« Reply #1 on: Sat, 27 August 2011, 04:34:16 »
Not quite. It fits, but the shape of the key is a tiny bit different.
On the Kinesis Advantage, the , , , <'> and '#' keys have the profile of the home row -- not that of the bottom row.
fossala
  •  Guest
« Reply #2 on: Sat, 27 August 2011, 04:35:26 »
Is there anyway to get replacement keycaps made for a whole set with a custom layout?
