Author Topic: Two Model F AT keyboards  (Read 5921 times)
Offline Daniel Beaver
« on: Mon, 29 August 2011, 20:08:55 »
Here <- EDIT: This is NOT an IBM board.
and
Here (in the original box, though by no means NIB)
They look good. Buyers beware: I fully intend on winning the first one, so back off :)
« Last Edit: Mon, 29 August 2011, 22:46:28 by Daniel Beaver »
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
Offline ironman31
« Reply #1 on: Mon, 29 August 2011, 20:12:57 »
Is that first one really an IBM? I've never seen one like that.
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/ATNoppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline jpc
« Reply #2 on: Mon, 29 August 2011, 20:49:42 »
The first one is missing Frankenstein's bolts (the riser adjusters) that IBM F ATs have. The black painted bottom and style of labeling reminds me of vintage BTC boards. Those are some weird stepped keycaps.
Some PC clone-maker cloned the AT keyboard. It's similar... that pencil ledge probably fits genuine IBM pencils...
« Last Edit: Mon, 29 August 2011, 21:13:49 by jpc »
RSI prevention recipe:[/B] Kinesis Contoured, Colemak layout, touch typing, Contour Design Rollermouse,  Logitech TrackMan Wheel, Logitech m570 trackball, "workrave" break timer software, "awesome" window manager, tenkeyless boards, cherry browns, Wang 724 with "ghetto green" ALPS, standing desk and/or comfy adjustable chairs, stress reduction, computer time reduction.
Fun non-ergonomic things: bolt modded Model M Space Saving Keyboards with new springs, Kensington Expert Mouse v7, Unicomp Endurapro, Northgates
Offline False_Dmitry_II
« Reply #3 on: Mon, 29 August 2011, 21:01:39 »
Ah, I looked at the layout and was like, at first glance it looks fine.
Could always be some modded thingy.
Offline Sam
« Reply #4 on: Mon, 29 August 2011, 21:10:36 »
In my opinion, the first on is absolutely not an IBM.  I've never seen any IBM keyboard with labeling even remotely matching that one.  When IBM came out with their PC and later AT, many companies tried to duplicate the look of the IBMs.  In my opinion, that is all this is.  But I'd be very surprised if it has buckling springs.  Buyer beware.
« Reply #5 on: Mon, 29 August 2011, 21:24:44 »
Given the age, at least it isn't likely to be rubber dome.
Offline jpc
« Reply #6 on: Mon, 29 August 2011, 21:40:25 »
It could be foil on foam which is about as lousy to type on (but maybe more durable)
Offline 8_INCH_FLOPPY
« Reply #7 on: Mon, 29 August 2011, 22:40:13 »
I have 2 keyboards that look identical front and back to the one in the first picture. They are both high-quality, double-shot black cherries. Unfortunately they are also both XT. I would guess that this one is the same, but I am sure that this is not an AT model F made by IBM.
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
« Reply #8 on: Mon, 29 August 2011, 22:40:34 »
You guys are right, that first one is definitely not an IBM. Too bad.
« Reply #9 on: Mon, 29 August 2011, 22:46:05 »
Grrr... how the hell does one go about contacting the seller about this? I'm trying to get into contact with him to tell him he doesn't actually have an IBM board listed...
Offline Sam
« Reply #10 on: Mon, 29 August 2011, 22:49:17 »
Well, Daniel, you said you wanted the first one, so go for it! :smile:  No backing out now.
To contact a seller, just click on their name and it will take you to a new page.  Then click on the "contact member" link.
Offline Sam
« Reply #11 on: Mon, 29 August 2011, 22:55:05 »
Quote from: 8_INCH_FLOPPY;407183
Perhaps this is a different model by the same manufacturer being it actually says "AT" on the underside label, so I assume it will probably work with an AT aka modern PC with a PS/2 adapter.  The key layout matches the IBM AT, not the XT, and includes the AT's SysReq key.  Notice they have LEDs embedded in the keys, not the separate LED lights as IBM boards.  Definitely doesn't look like an el cheapo board.  If it's double-shot black cherries as you say, I could see someone being interested in it.  Just not me.
« Reply #12 on: Tue, 30 August 2011, 05:50:09 »
We'll see. If the price stays very low, I'll buy it. But the seller needs to change the description or else I'm going to report him.
« Reply #13 on: Tue, 30 August 2011, 14:22:00 »
I think if you could handle the layout, it would be a nice one to mod to whatever switches are your favorite (and probably the coloring too). Should have better build than anything else on the market currently.
Quote from: Sam;407189
That and I'm pretty sure XT has no such lights period.
Offline Sam
« Reply #14 on: Tue, 30 August 2011, 18:13:43 »
Quote from: False_Dmitry_II;407587
Correct, the XT interface is unidirectional (Keyboard->PC), thus no LEDs.  The AT interface is bidirectional, thus the PC can control the LEDs.
Offline Sam
« Reply #15 on: Wed, 31 August 2011, 22:46:43 »
With the true IBM board now at $91 and about a day remaining, nobody will be getting a steal of a deal on it.  I guess the days of $75 IBM AT boards are over.  Seems $100+ is the new going rate.  Glad I got mine while they were relatively cheap.
« Reply #16 on: Wed, 31 August 2011, 23:13:54 »
Too bad, but I'm going to back out of the bidding war. I'll nab a Buy It Now eventually.
I might buy that off-brand one just to see what it is.
Offline ironman31
« Reply #17 on: Thu, 01 September 2011, 14:39:39 »
Quote from: Daniel Beaver;408503
Just be patient. That's how I ended up getting one for 50 USD shipped BIN.
Keyboards:
Pointing Devices:
Offline JBert
« Reply #18 on: Thu, 01 September 2011, 14:53:32 »
Or wait for a mislabeled one to come up - my AT keyboard was labeled as an XT on Ebay but I recognized it for what it was thanks to the picture. Bought it once the seller confirmed the picture was the real deal...
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline sordna
« Reply #19 on: Thu, 01 September 2011, 19:58:43 »
15 minutes left for the IBM one:
http://www.ebay.com/itm/110735249885?ssPageName=STRK:MEBIDX:IT
How much do model F AT's go for usually, what's the average price ?
Offline sordna
« Reply #20 on: Thu, 01 September 2011, 20:17:04 »
Do model F AT's go for more or less than SSK's usually?
Offline Sam
« Reply #21 on: Thu, 01 September 2011, 20:33:50 »
Of late, the PC AT boards seem to be going for about $100 - $125, depending on condition, and various factors.  Late last year and into the early part of this year they were going for about $70 - $80, with some in the $50 range if the condition wasn't so good.  I bought six of them during that time for $50 or less.
So as of right now, the average is slightly less than SSKs, but there were several SSK sales last month in the $70 - $80 range, which were considerably less than the current PC ATs.
Offline Sam
« Reply #22 on: Sun, 04 September 2011, 21:10:01 »
There was another AT board that just closed at $54.77:
http://www.ebay.com/itm/290604330112
For anyone wanting to get a cheap AT board, looks like you missed your chance, other than whoever it was that won the auction.  Not sure why more people weren't interested in it.  I would have bid myself, but noticed it was a fellow Geekhacker bidding on it (or at least I think it was), and figured I have plenty of them as it is.  'R', hope your enjoy the board.
« Reply #23 on: Mon, 12 September 2011, 14:08:50 »
I was the unfortunate one who bought the fake AT board. When I saw the listing I put in an Auction Snipe for $55 and then never went back to see the Q&A section to realize that it was not an IBM, I didn't know but kind of assumed that the badge had been peeled off, or it was some sort of OEM situation.
I also had never discovered this "great finds" thread until after the purchase was complete, or I would have learned about the origin of the board in time.
Having said that, I must say that the seller, Box Lot Dude, was decent enough when I complained that the item was not as described, but acted very haughty and said that he was refunding more than what I had paid, but it was actually just about the right amount. I offered to send the board back at my expense, since I had not read the fine print in time, but he told me to throw it out into the middle of the road.
Since you must be interested, and I am too, here is a picture.
[ Attachment Invalid Or Does Not Exist ] 26466[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 26469[/ATTACH]
There is no click at all, I have not had a keyboard with these switches before. And I don't think that it is just the board chow dampening the sound.
What quality of switches are these "Hi-Tek" models? How well are they regarded?
I am in a strictly buckling spring phase right now, although I do have a couple of sliders that I am hanging onto, so I would love to find a home for this keyboard. It is not a bad board, for what it is, and all the keys work. The guy was certainly right when he said it needed cleaning.
Are any of you interested in this keyboard?
thanks
- Franklin Roosevelt 1933
Offline theferenc
« Reply #24 on: Mon, 12 September 2011, 17:53:01 »
Aren't those Space Invaders? That's a switch I've been wanting to try, just to try it.
Ninja edit: Yes, yes they are space invaders.
« Reply #25 on: Mon, 12 September 2011, 18:18:21 »
At least it was something half-way interesting. Is it NKRO perchance?
« Reply #26 on: Mon, 19 September 2011, 20:31:55 »
In case any of you are interested, on a theoretical level, and somebody must be, since I did get a couple of comments and private messages after my last post, I listed this beast on ebay today for $35 with free shipping, and sold it in under an hour (although several hours later, they still have not paid).
This buyer has bought from me before (an old Key Tronic re-branded as a Dell). It is probably headed for Korea, as far as I can tell.
Obviously, when it sells in under an hour, it was priced too low, but I offered it to people here for less and no one seemed interested, presumably since it was not clicky (and that's why I didn't want it either).
This site/forum is still a little hard for me to search. Is there an easy way to get advice and/or help identifying odd old keyboards and switches, other than just posting to the main board?
thanks
Offline BiNiaRiS
« Reply #27 on: Tue, 20 September 2011, 01:29:48 »
Quote from: harrymoss;418869
Not always. If it was priced well, sometimes you just find the right buyer...especially on items that don't pop up that often. The buyer just happened to look right after you posted.
« Last Edit: Tue, 20 September 2011, 04:57:09 by BiNiaRiS »
KMAC 2 w/ErgoClears
