Author Topic: Das Keyboard vs. Cherry G80 3000  (Read 2076 times)
Offline mcc
« on: Tue, 30 August 2011, 22:23:44 »
Hi,
on this forum I read, that "Das Keyboard II" is technically identical to a "Cherry G80 3000".
Is there another technical brother/sister of the recent "Das Keyboard Model S"?
Thank you very much for any help in advance!
Best regards,
mcc
Offline Arcanius
  • Buckling Spring Lover
« Reply #1 on: Tue, 30 August 2011, 22:46:45 »
The Das III and S have no cousins like that, they're an independent design, produced by Costar. The keycaps are identical to Filcos, except for the printing method. There is a review comparing the Filco and Das Keyboard, which are probably most similar of keyboard, having the same manufacturer.
Offline megnin
  • Topre, or not Topre? That is the question.
« Reply #2 on: Fri, 24 February 2012, 08:40:11 »
Quote from: mcc;407817
I have a Das Keyboard II and have notice the similarity.  I just found this thread while searching for references.
I think they are the same.  Look at the Num/Caps/Scroll lock lights on both of them.  They are identical.
“The only difference between me and a madman is I'm not mad." -- Salvador Dali
