Author Topic: What's the ideal keyboard layout for you?  (Read 1988 times)
Offline spdx
« on: Fri, 09 September 2011, 16:10:17 »
There many interesting keyboard layouts out there but none of them is ideal for me.
MY close-to-ideal keyboard layout is between a 87-TKL and a KBC poker. Like a TKL without function keys rows, which can be merged into number/symbol rows with an FN key:
ESC --> ~`               as KBC poker but with ESC enabled in initial state.
F1-F12 --> 1..0,-,=
PrcSc/ScrLk/Pause --> Insert/Home/PageUp
What does your ideal keyboard layout look like?
Offline Oqsy
« Reply #1 on: Fri, 09 September 2011, 16:16:56 »
101 key ANSI
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline HairyTroll
« Reply #2 on: Fri, 09 September 2011, 16:21:03 »
HHKB Pro 2, but with the addition of the inverted T cursor keys.
Offline Daniel Beaver
« Reply #3 on: Fri, 09 September 2011, 16:31:17 »
My modified Model F AT layout was basically ideal in my mind. The only thing missing was the F11 and F12 keys, which are annoyingly placed on the far right side of the keyboard.
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
Offline pyro
« Reply #4 on: Fri, 09 September 2011, 19:33:15 »
Dvorak and HHKB layout as a base. Capslock as Backspace, Tab and / as Shift Keys, and Escape as Numpad-modkey (including an extra modkey for the Shift-layer for $%^ etc) modded in.
(Tab, /, and Escape send their original keycodes when pressed alone or with other modkeys.)
« Last Edit: Fri, 09 September 2011, 19:36:28 by pyro »
