Author Topic: IBM model M: "Reseating springs/keys" ???  (Read 1445 times)
Offline mcc
« on: Sun, 11 September 2011, 09:56:52 »
Hi,
I read, that IBM model M users had "reseated" the springs/keys of their
Model Ms.
Two questions out of pure curiosity:
How can I determine keys which need to be reseated?
What do I have to do to "reseat" a sping/key?
Thank you very much in advance for any help!
Best regards,
mcc
Offline Ascaii
« Reply #1 on: Sun, 11 September 2011, 15:34:52 »
Also, if a switch works fine but doesnt click, that means the spring is not tight on the hammer and needs reseating.
Offline NewbieOneKenobi
« Reply #2 on: Sun, 11 September 2011, 15:53:15 »
Springs are removed by turning them either clockwise or counterclockwise (I don't remember which) delicately, the reverse for putting them back on. It can be done with bare hands, though it may require some concentration. Pincers or bamboo stickers can be used instead. I prefer just bare fingers.
Offline cactux
  • Topre Knight
« Reply #3 on: Sun, 11 September 2011, 20:48:34 »
Some times if you just removed the keycap and put it back the click comes back. I tried this with a few keys and it works
[FS]☠ The temple lol ->HERE<-
