Author Topic: What your fav mouse?  (Read 1169540 times)
Re: What your fav mouse?
« Reply #1800 on: Wed, 22 November 2023, 10:33:40 »
vertical is so comfortable for me
True "vertical" mice suck, in my opinion, because pushing a button moves the mouse (equal and opposite reaction) and you must restrain it with your thumb, an unnatural motion.
I love pseudo-vertical mice (which might better be called "diagonal") because you get the advantage of better wrist geometry but can keep the body of the device steady as you push the buttons. I started with a Wow Joy Pen years ago and when it died I got an Anker which I like better. Too bad they don't make a left-hand version because I keep mice on both sides, but a trusty Microsoft Wheel Mouse Optical is a good simple ambidextrous choice for my secondary mouse.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
"The pure products of America go crazy"
- William Carlos Williams - "For Elsie" 1942
Offline funkmon
« Reply #1801 on: Tue, 28 November 2023, 11:15:21 »
I agree completely man; vertical mice mean thumbstrain. Hated using one.
Offline mohawk1367
  • Typing on: HHKB Pro Hybrid Type-S
« Reply #1802 on: Wed, 20 December 2023, 08:13:00 »
rn i use a Fantech Aria XD7 (switched from a Razer Orochi V2 which i loved also) and I really love it but the battery life is so garbage even compared to the Orochi so im trying to find if theres something similar i can get with better battery... might just have to go back to the Orochi
for work i use an MX Master 3S which is great but the shape and weight arent ideal for gaming obviously
someone needs to make an aussie keyboard community called QMƎɹ┴⅄. get it? haha :D
Offline TomahawkLabs
« Reply #1803 on: Wed, 20 December 2023, 15:07:29 »
Been using a Shark SK137G wireless mouse at work. I like it because it's in between vertical and horizontal (but a lot more comfortable). It feels like it follows the natural curve of my wrist/hand.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
Offline transeurasian
« Reply #1804 on: Mon, 25 December 2023, 11:57:16 »
Logitech G1 cuz I have small hands :rolleyes:
« Reply #1805 on: Mon, 01 January 2024, 10:02:43 »
But I own 2 other logitechs. G302 and G Pro.
For office and CAD work they seem small enough to be moved in your palm, without having to move the arm at all.
Offline atarione
« Reply #1806 on: Tue, 06 February 2024, 11:50:52 »
I am left handed ..but switch back and forth between left and right handed mousing(??)      For what seems like ever at this point I have used a Steelseries Sensei of some sort or other..
orig Sensei / Sensei MLG / Sensei 310 / currently Sensei Ten
I have big hands and a palm grip the Sensei accommodates this well.
Offline pelfox
« Reply #1807 on: Tue, 06 February 2024, 13:17:54 »
best mouse to me, logitech g pro superlight. this mouse is seriously a game-changer.
its ergonomic design molded perfectly to my hand, the surface texture is ok but could be better, every click is a responsive. it's like it was custom-made just for me. i can't imagine using anything else now, worth every penny
en boca cerrada no entran moscas
Offline cfw
« Reply #1808 on: Sun, 18 February 2024, 14:31:17 »
Logitech MX Master 3s at home, MX Master 3 at the office.
Both configured in freespinning mode.
Offline mathisart
« Reply #1809 on: Fri, 10 May 2024, 09:15:45 »
I don't really have a favorite, but I like the logitech g600
Offline Geke_Hackman
« Reply #1810 on: Mon, 02 September 2024, 21:37:21 »
Logitech g502
Offline Scrambler_S
  • Sic semper tyrannis
« Reply #1811 on: Sun, 08 September 2024, 07:11:57 »
Razer VMSE current mouse on Wallhack SP-004 glass.
Offline Osidian
« Reply #1812 on: Sun, 08 September 2024, 13:17:33 »
Logitech G Pro for gaming, its got a great sensor and its super lightweight, but I enjoy using the Cobra Pro too, for its build quality.
« Last Edit: Sun, 08 September 2024, 13:39:21 by Osidian »
Offline Darthbaggins
  • PC Cannibal
« Reply #1813 on: Mon, 10 February 2025, 10:51:19 »
I have ditched my Logitech mice until they fix the scroll encoder issues - moved to the Lamzu Maya 4k/X and have been loving it, only thing Logitech has on lock is the battery life.
Offline knightjp
« Reply #1814 on: Wed, 19 February 2025, 06:03:21 »
Currently with my limited experience with trackballs, my fav is the Elecom Huge. I know that the common consensus is that the ball movement is scratchy and most people change out the bearings, I've not faced that issue so far. The ball movement is smooth for me.
The number of buttons and if you are on Windows /Mac, the way that you can customize the options with it is great.
There are only a couple of things that I do not like about the HUGE. One thing that I do not like is that the rubber wrist rest on the HUGE is starting to wear away and now once the top layer is gone, you get this black powdery residue - pretty much like dust.
The other is when you have to click and hold left click and then scroll at the same time. For that I think the Kensington Slimblade is better in its form factor or even a Thumb operated ball like Logitech M570 is better - both of which I've used before.
However I will state that HUGE lasted longer than the Slimblade.
Offline aleck
  • im so full of topre yum
« Reply #1815 on: Wed, 26 February 2025, 20:11:27 »
Currently using a Microsoft Intellimouse 4.0, it's a little gunky but I wouldn't trade it for anything. The only gripe I have with it is that its highest DPI setting is far too low for my 2K display and libinput won't let me artificially crank it up past a certain point, but I live with it.
HHKB Pro 2 Type-S (2016)
Offline YALE70
    • Hackjob
« Reply #1816 on: Sat, 01 March 2025, 22:22:02 »
I'm a weirdo who keeps both a mouse and a trackball at my desk, but I've pretty well settled on my choices for the two of them. Here they are:
Razer Basilisk V3 Pro: Has virtually every feature under the sun, packed into a very G502/MX Master-like body. Butter smooth on wireless and the sensor tracks on my glass desk. The battery life is only okay, but I just dock it whenever I'm not using it (which is most of the time nowadays). Smart Reel is undoubtedly a gimmick, but it's neat. My main complaints is that it's not made out of PBT - which is insane to me given how expensive this mouse is, and that Synapse 4 is a total resource hog for no good reason. Otherwise, it's about as good of a combination work and gaming mouse that you can get in my book.
Microsoft Trackball Explorer: I bought this and a few other trackballs just to satisfy my curiosity - and I haven't been able to stop using it. It's quite comfortable and the sensor still feels plenty fast for my 3440 x 1440 display. The 46mm ball is just the right size for me and the chrome steel bearings have relatively little stiction. I also like the red glow ring surrounding the ball which really drives home that early-2000s optical mice aesthetic. Software is lightweight, and there's plenty of buttons to map out. This thing has almost completely replaced the Basilisk at my desk for virtually everything except for FPS games. Kind of a bummer there isn't really a perfect replacement for it though.
Honorable mentions:
  • Razer Mamba 2015: IMO, still just as good as any of Razer's current premium mouse offerings, minus nearly as heinous of a software experience. I kinda regret selling mine...
  • Microsoft Arc Touch Bluetooth Mouse: I freakin' loved this thing for travel. Folds almost completely flat and it feels more natural to use than it looks. The haptic scroll "wheel" actually feels pretty convincing. Also regret selling...
  • Logitech Trackman Marble FX: Out of all the trackballs I've owned, this has the best shape, hands down. Unfortunately, time has caught up to it and trying to work with that sensor is just pure pain. One of these days I'd like to try and fix it.
  • Logitech Cordless Optical Trackman: Same situation as above - really great shape (but not as good as the FX), old and slow sensor, all made even worse by 27 MHz RF wireless and a 50 Hz polling rate. This thing deserves to be so much better.
Offline JackQn
« Reply #1817 on: Mon, 07 April 2025, 16:25:55 »
Logitech G502, I have bought at least 5 G502s over the past 5 years. :p Highly recommended.
Offline pnoozi
  • I was annoying at a KeyCon, so now I pay more 🤷
« Reply #1818 on: Mon, 09 June 2025, 14:27:03 »
For competitive shooters nothing bests the Zowie EC2.  It's the perfect size and shape and the rounded button edges are the cherry on top.  Classic DeathAdder shape is a close second.
For productivity, Logitech MX518 and G703.  Really anything with lighter clicks (Omron 50M switches).  Unfortunately the industry has moved on from those due to widespread double-clicking and nothing else feels comparable.
« Last Edit: Mon, 09 June 2025, 14:29:50 by pnoozi »
Filco Majestouch 3 TKL (Red) | Nuphy Air75 (Brown)
Offline guily6669
« Reply #1819 on: Thu, 03 July 2025, 20:13:15 »
This thing:
Weird, has it's issues, but since the 90's I never had this totally different sensation, had a blast playing strategy games with it  ;D
ps: But definitely not my main mouse haha.
« Reply #1820 on: Mon, 07 July 2025, 17:18:57 »
My Zowie EC2 has lasted me FAR longer than mice that cost 2-3x more
No frills, no weird shape, it just works.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #1821 on: Sat, 16 August 2025, 07:32:53 »
I am using the Swiftpoint Z2 for some years now...
To me it was an absolute game-changer for productivity!
It has a lot of buttons, but unlike MMO-mice with their clunky thumb-grids, the buttons are smartly placed to keep the hand in a natural position.
You get 11 buttons under the main part of your hand, plus 2 thumb buttons, allowing you to execute commands without shifting your grip.
5 of the buttons feature a pressure-sensitive "Deep Click", allowing multiple actions on a single press (based on how hard you push).
You can set haptic feedback to these buttons providing tactile confirmation of actuation levels, helping you to build muscle memory.
The software works like a charm for me...
In difference to many others, the auto profile-switching works flawless.
You can assign complex macros, keystrokes, or program-specific actions to each button.
With onboard memory for 20+ profiles, you can save setups for all kinds of different workflows.
I liked the Swiftpoint Z2 so much that I got 3 more when they went on sale.
Just to have backups in case they stop making them (...it is a small company).
I can’t imagine my workflow without this mouse—it’d seriously mess things up.
314097-0
For super twitchy FPS, the Z2 is too heavy and too complex (for me).
Here I use the Endgame Gear OP1 8k currently...
It does not require any software, but you can change the onboard setting with software if needed.
It is very light (50g) and has a simple shape. It is available as wired and as wireless variant.
You can mod/swap it's switches easily, and replacement switches are easy to get.
314099-1
« Last Edit: Sat, 16 August 2025, 07:38:57 by TheSoulhunter »
A Ghost From The Past
Offline smarmar
  • It don't mean a thing if it ain't got that swing
    • Short Stories from an Old Library
« Reply #1822 on: Mon, 01 September 2025, 20:59:35 »
I'm a Logitech lad.
G400, G9x, MX518, and the legend: the G5
I'd have to say the G400 is the best mouse I've ever used. It's simple, wired, just the right number of buttons, perfect ergonomics, and optical (cool, red light  :thumb:)
1992 IBM Model M | Tesoro Durandal[Browns] | Hi-Tek Series 725[Space Invaders] | Tandy Enhanced[Sliders] | Dell Quiet Keys | Mitsumi[AT]
« Reply #1823 on: Thu, 20 November 2025, 02:32:26 »
this is a nostalgic image for me
