Author Topic: USB Cable fix?  (Read 1103 times)
Offline JustCallMeCrash
  • ErgoDox Lover
USB Cable fix?
« on: Thu, 15 September 2011, 19:33:26 »
I have a PCB for a Filco tenkeyless on the way from martinmeijerink which has a damaged cable.  He's sending the PCB and the controller board as well as the damaged cable (I figure I can salvage that white bit).  What I'd like to do, since I have to make my own case, is to mod this to be more like the Poker (I'm going to have it in my laptop bag and don't want the cable to be too easily damaged, so I'd like to be able to remove it. I have a ton of those mini-usb cables laying around from all the various phones I've had, so I won't have to worry about damaging the cables.  I'm wondering how difficult it would be to mod this male-female cable onto the original cable connector. [ Attachment Invalid Or Does Not Exist ] 26691[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 26692[/ATTACH]
I haven't cut open any USB cables before (never had a need to) so I'm unsure what to expect when I do... will this be fairly straightforward?  Any guidance is appreciated.
Thanks.
ErgoDoxen 6 total: Cherry MX Browns, Cherry MX Clears, NovelKeys Box Royal, 80g Gateron Yellows, NovelKeys Pale Blues, NovelKeys Box Navy.
Preonic 2 total: OG Gateron Yellows (GMK silencer clips), TBD (unassembled v2).
XD-75 (mixed Gateron Yellows, MX Blacks, MX Clears on layer toggles).
Das S Professional (was MX Blues, now Ghetto Reds).
G80-11900.
ML-4400 (2x) Cherry MY boards.
