Author Topic: Is this mechanical keyboard? Is there a way to plug it in PS/2 port? (links added)  (Read 2879 times)
Offline jacynt
Hello,
Does anyone have idea if it is mechanical keyboard? I hadn't much success with googling information about it.
In thread "IBM 1386887 (3179 terminal) keyboard conversion" is concept how to connect terminal keyboard to the ps/2. Does anyone know if it is doable with that one? I know it might be dangerous for PC, but I willing to try anyway.
Does using USB ethernet modem can make it work?I do not have enough knowledge to contemplate about this solution. If some of you can do it, feel free to do so.
What I'm looking for is to plug in this keyboard to the ps/2 port and use it for typing and games. I find it is cheapest way to test out mechanical keyboard. Even taking under consideration danger of PC damage. I have old spare one for test.
http://i860.photobucket.com/albums/ab166/Jacynt/Zdjcie004.jpg
http://i860.photobucket.com/albums/ab166/Jacynt/Zdjcie005.jpg
http://i860.photobucket.com/albums/ab166/Jacynt/Zdjcie010.jpg
http://i860.photobucket.com/albums/ab166/Jacynt/Zdjcie007.jpg
http://i860.photobucket.com/albums/ab166/Jacynt/Zdjcie009.jpg
http://i860.photobucket.com/albums/ab166/Jacynt/Zdjcie008.jpg
http://i860.photobucket.com/albums/ab166/Jacynt/Zdjcie001.jpg
http://i860.photobucket.com/albums/ab166/Jacynt/Zdjcie010-1.jpg
PM me the link, maybe I can help.
Offline jacynt
Thanks, I have send you the pm. Apparently new user like me is not allowed to add any url to threads.
Offline jacynt
worse,whole figure appears.
And he says something like:
New users are not allowed to use url links in their threads. Make sure you don't have any forbidden words.
Edit: well, i guess I'm not new anymore, since finally I could paste those URL
Offline Phaedrus2129
I don't recognize those switches. Might be some obscure switch no one ever heard of, or they might be sliders over rubber domes.
Keycaps look doubleshot though.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline jacynt
Yes, it looks identical. It looks like for now I must forget about testing mechanical keyboard.
Offline slueth
Seem like a fake topre :X Does it feel good?
It has very flat looking switches, I would agree with the rubber dome assessment. It is quite thin too (although there are some thin mechs). Its a terminal board so you would have to do the conversion, unless it is rj11, in which case there is a converter to get it so USB but you would probably be better off with a teensy.
Offline jacynt
Quote from: ripster;418339
I'm sorry to bring you the bad news.
But identifying the switch.....
It's better to know this now, before I get more involved in to testing:) Thanks
Quote from: slueth;418333
Are you asking how does the pushing buttons work? Well, it gives resistance at the first touch, and then it is very easy to bottom it out. But I didn't use it so I can't say when OS register pressed button.
Quote from: QualityMechKeyboards;418452
I guess I will have eyes wide open to find Model M in my country. It will be much more convenient than adapting terminal keyboard.
Quote from: Phaedrus2129;418313
You were right with rubber domes.
Thanks for your involvment guys.
