Author Topic: Lowest profile mechanical?  (Read 6467 times)
Offline graywolf
    • http://www.graywolfphoto.com/
« Reply #50 on: Wed, 28 September 2011, 14:58:43 »
Quote from: ripster;422109
A IBM buckling spring has no moving metal contacts.
I'm pretty sure most Geekhackers consider IBM Model Ms to be mechanical.  They ping for example.   I don't recommend using ping as the determining factor.  People get upset and report me when i say Ping.
I type 100% on a Model M, I have taken it apart. I even posted photos on GH. It IS a rubber dome keyboard. Of course, it does have a lot of mechanical stuff between the rubber dome part and your fingers to make it feel good. Rubber dome keyboards are not bad keyboards. Bad keyboards are bad keyboard however they are made. And, of course, good keyboards are good keyboards however they are made.
By the way mister expert, what kind of key switch did they use in the IBM Selectric Typewriters? Some times what I think I need is a Selectric Terminal for my computer.
Offline Clickey
« Reply #51 on: Thu, 29 September 2011, 06:32:49 »
Pretty sure the selectric uses capacitive switches
"we are on Geekhack not Lazy****" - The Solutor
Offline Lenny_Nero
« Reply #52 on: Thu, 29 September 2011, 07:11:57 »
Free BSD with a pretty face is what I say.
Thats what I understand it to be, free BSD with the Darwin shell on top.
But then I am able to resist the "Jobs reality distortion field"
As to the op if your keyboard it too high move your chair up a bit.
Filco Zero, Viglen DFK 2020UKF104, DTK SPK-102a, Panasonic Biz 500
Ducky 1087 Chicony KB-5191, G80-1856HQMGB Cherry G80-1000HFD and others
 G80-11908HRMIT, Tipro MID-KM128a, Access AKEOXPB312/2 (20x7), Access AKEOCTI635/1(15x6)
Offline Ekaros
« Reply #53 on: Thu, 29 September 2011, 08:16:06 »
Isn't Model M membrane keyboard? And there is mechanical hammer over membrane, rubberdomes have rubberdome over membrane? So they use same basic technology two plastic sheets which make circuit when contacted. Difference is what makes these contact, each other. Acer switch uses same principle, but much more basic.
So I should add something useless here yes? Ok, ok...
Filco 105-key NKRO MX Browns Sw/Fi-layout|IBM Model M 1394545 Lexmark 102-key Finnish-layout 1994-03-22|Cherry G80-3000LQCDE-2 with MX CLEAR
[SIGPIC][/SIGPIC]
Dell AT102W(105-key SF) (Black ALPS)|Steelseries Steelkeys 6G(MX Black) ISO-FI-layout|Cherry G84-4400 G84-4700 Cherry MLs
Offline peda
« Reply #54 on: Thu, 29 September 2011, 08:27:32 »
Now you guys are just cruel.
Ripster's head will explode when he comes online.
Anyway on topic: arplot, did you find your answer already?
woody
  •  Guest
« Reply #55 on: Thu, 29 September 2011, 09:44:58 »
Quote from: peda;423315
Lowest profile mechanical? Perhaps the Cherry G84 series as already pointed.
Offline arplod
« Reply #56 on: Sun, 23 October 2011, 05:38:34 »
So just to bookend this thread, Yes I did thanks. Thanks to those who posted answers.
Offline sapht
    • http://sapht.com/
« Reply #57 on: Mon, 24 October 2011, 20:42:29 »
Why low profile?
I find flat keyboards encourage me to rest my wrists near their base which increases wrist pain, rather than decreases it. I have a Cherry ML-84 and it's basically good for nothing. Wouldn't use it for anything except being my only compact PS2.
In opposition, the keyboard I feel the least pain using is the Model M, because it /requires/ me to pull my wrists up and use real muscles to type on the keyboard in order to actually depress any keys. And that keyboard has like the biggest curvature I've seen. Love how it positions those F1-12 keys, can hardly stand the regular flat layout since getting it.
Current hoard: Filco Majestouch Tenkeyless Brown, Das Keyboard II Professional Blue, IBM Model M double shot keycaps, HHKB2 blank white
