Author Topic: Failing (defective?) switch on Filco Tenkeyless  (Read 1566 times)
Offline dfrey
« on: Fri, 23 September 2011, 14:13:29 »
I bought a Filco tenkeyless "Otaku" edition keyboard (Cherry brown switches) from EliteKeyboards two or so years ago and I think one of the switches is sort of broken.  The problem I'm having is that when I press my "Home" key, sometimes the key press doesn't register.  If I press it hard, it always works.  It seems like the tactile bump occurs at a higher level than key activation so I can feel that I pressed the key, but it doesn't actually produce a keystroke.  I haven't noticed this problem on any other keys.
Aside from the rapidly de-laminated keycaps, I was really happy with this keyboard until this issue appeared.  I was really expecting this keyboard to last a lot longer than two years.  How difficult is it to replace a switch in a Filco keyboard and where is a good place to get a switch from (I live in Victoria, BC, Canada)?
Offline Lanx
« Reply #1 on: Fri, 23 September 2011, 17:16:07 »
de-solder 2 switches (use scroll-lock donor switch) then re-solder, depends if you know how to solder or not, otherwise you'll make a mess learning, hopefully nothing burns.
