Author Topic: Realforce 10th anniversary model released in Korea  (Read 48953 times)
Offline jcrouse
« Reply #100 on: Thu, 07 June 2012, 17:29:01 »
In the bottom picture on post 64 you can see there is an LED on the left control key. Why and how do you activate it?
Thanks,
John
Offline ironman31
« Reply #101 on: Thu, 07 June 2012, 19:33:38 »
it's a caps lock light. Not sure why they printed control on the key...
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/AT,  Noppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline funxion
« Reply #102 on: Thu, 07 June 2012, 19:42:28 »
They're swapped...
Crush80
Filco MJ2 TKL
Offline ironman31
« Reply #103 on: Thu, 07 June 2012, 22:33:19 »
But why wouldn't they have the small key in the corner have "caps lock" printed on it when it has a window?
Keyboards:
Pointing Devices:
