Author Topic: Repairing Old Das Keyboard  (Read 1556 times)
Offline Chrontius
« on: Tue, 04 October 2011, 17:24:22 »
Long story short:  Das Keyboard, Mk.1 with busted USB plug.  Cut off cord, soldered on Sparkfun supplied micro-USB plug, and… ten attempts, failing to enumerate the device.
Seemed like the ground was uninsulated, and in contact with the shielding.  Is this bad?
Offline Minskleip
« Reply #1 on: Tue, 04 October 2011, 17:34:34 »
The PS2 cables I've cut up was like that - thought that was normal. If you're talking about the "cable ground", that is. The other ground should be insulated.
What\'s in the back of my car? A cdr lol
Split Tipro keyboard with R3 keycaps
Offline Chrontius
« Reply #2 on: Wed, 12 October 2011, 16:14:51 »
No, it's the ground that's supposed to be insulated that's bare.
