Author Topic: Help identifying some Unicomp 122 key terminal emulator boards  (Read 2884 times)
Offline mr626
« on: Tue, 11 October 2011, 01:33:17 »
Hi all,
I'm trying to work out if a couple of boards are buckling spring or not. They are apparently brand new from Unicomp. Relevant part / model numbers are as follows:
-Unicomp 122-Key PS2 Terminal Emulator Keyboard UNI0T52
-Unicomp Terminal Emulator PS2 Keyboard NEW AK278AA-ABA
-Unicomp 122-Key Emulator PS2 Keyboard NEW 953604-010
The first two look like this:
[ Attachment Invalid Or Does Not Exist ] 28366[/ATTACH]
The last one looks like this:
[ Attachment Invalid Or Does Not Exist ] 28367[/ATTACH]
Any ideas?
Offline theferenc
« Reply #1 on: Tue, 11 October 2011, 09:22:56 »
I know the first is not, as I have one. The latter two I think are not, as I've emailed that seller before and been told none were (at the time). I don't recall if those particular model numbers were listed, though.
I can tell you though that it's a really nice rubber dome, for sure. And it can be converted to a buckling spring, or the controller used to swap into a non-working other model, etc. Basically, it's nice and quiet, or useful for parts.
Offline mr626
« Reply #2 on: Tue, 11 October 2011, 17:34:22 »
Ha, I was wondering if you would be the one to reply :-)
Yeah, I've emailed the seller previously but too be honest I don't think they are that interesting in providing useful information- at least that was the impression I got.
I suspected they weren't buckling spring, but I've seen the exact same model number(s) as shown above advertised elsewhere as being 'clicky' For example:
http://www.codemicro.com/store/product/AK278AAABA/New
I wish there was a good complete guide to Unicomp model numbers etc somewhere. Maybe I'll email Unicomp directly and ask them...
« Last Edit: Tue, 11 October 2011, 17:38:31 by mr626 »
Offline theferenc
« Reply #3 on: Tue, 11 October 2011, 18:28:40 »
Good luck with that one. Unicomp is a great company, but they can be seriously slow sometimes.
I'll try and remember to ask tomorrow when I call them about a question I asked nearly 3 weeks ago...
Offline mr626
« Reply #4 on: Thu, 13 October 2011, 05:17:20 »
Well, I got a reply from Jim at Unicomp:
The easiest way is to remove a button and see if there is a spring or a rubber dome. Of the three part numbers you listed, the UNI0T52 is one of our rubber dome models. I do not recognize the other two part numbers. Generally, part numbers that end in 6 are buckling spring, models ending with a 2 are rubber dome.
I guess that's something about the part numbers at least.
