Author Topic: blnak keyboard help  (Read 1758 times)
Offline Son of Gnome
blnak keyboard help
« on: Tue, 11 October 2011, 15:53:57 »
SO I just bought a das from a member here on geekhack. He bought it because the previous owner had keycaps he wanted, so he took the keycaps off and placed the old ones back on. However since they are blank it is possible that they could have been misplaced. Is there a way to know exactly what row each key goes in or will I just have to eye ball it and just figure it out?
EDIT the title is meant to have blank in it not blnak...
Offline siouxscout
blnak keyboard help
« Reply #1 on: Tue, 11 October 2011, 16:00:07 »
Wont matter really unless it has different sized\angled keys for certian rows.
[SIGPIC][/SIGPIC]
Offline Urglifast
blnak keyboard help
« Reply #2 on: Tue, 11 October 2011, 16:01:52 »
there are different key profiles for the different rows, i'll see if i can't find a picture to explain it before someone else does
[ Attachment Invalid Or Does Not Exist ] 28411[/ATTACH]
the das should have the DCS family profile to the rows if you look at it from the side.
« Last Edit: Tue, 11 October 2011, 16:04:14 by Urglifast »
Offline nikonf5
blnak keyboard help
« Reply #3 on: Wed, 12 October 2011, 13:39:47 »
Direct answer to your exact question can be found here:
http://blog.bogosity.se/2010/09/12/reassembling-das-keyboard/
Offline itlnstln
blnak keyboard help
« Reply #4 on: Wed, 12 October 2011, 13:49:54 »
Quote from: Son of Gnome;429098
Is that a trick question?
Offline shrap
blnak keyboard help
« Reply #5 on: Wed, 12 October 2011, 16:02:59 »
Quote from: itlnstln;429580
I would like to see the looks on people's faces when you say,
"I'm trying to figure if this blank key is in the right place."
Offline Urglifast
blnak keyboard help
« Reply #6 on: Wed, 12 October 2011, 16:05:32 »
Quote from: shrap;429746
hey hey hey, you never know, he could have accidentally switched the 'F' and 'J' keys!
some people don't know.  don't beat them up because they don't.
« Last Edit: Wed, 12 October 2011, 16:15:09 by Urglifast »
