Author Topic: How to bleach white keycaps yellowed by the sun  (Read 13549 times)
Offline popol
« on: Fri, 14 October 2011, 11:19:59 »
Do anybody of you have an easy method to bleach white doubleshot keycaps that have been yellowed by time and the sun? Old Omnikey 101 keyboard keycaps. They are mainly yrllowed by the side and are otherwise in good condition (almost not used on the top). What a shame.
Same for the case of the keyboard yellowed on some parts.
inside, plate and switches are looking great just like if this keyboard hasn't been used that much...
Offline popol
« Reply #1 on: Fri, 14 October 2011, 12:08:58 »
thank you very much for your help Ripster. I'll try to get used to and stick to the forum rules.
Offline popol
« Reply #2 on: Sat, 15 October 2011, 03:46:15 »
the chemical blend will be hard to produce and store in my very small flat.
Would be nice if somebody could produce a quatity of RotrObrite and sell to the community, ready to use, withof course an additional value in the price.
Offline REVENGE
« Reply #3 on: Sun, 16 October 2011, 03:03:04 »
Quote from: popol;431582
Per ripster, the jar method would be easy for you to make, use, and store. Basically a jar of hydrogen peroxide solution and catalyst.
Offline popol
« Reply #4 on: Sun, 16 October 2011, 09:11:50 »
Quote from: REVENGE;432157
can't find the link to this method into his sig
Offline sinis
Offline StaCT13
« Reply #6 on: Sun, 16 October 2011, 23:47:53 »
Also, if that 'signature' Retrobrite formula doesn't work, just immerse the whole thing in hydrogen peroxide. It takes closer to a week, but it got me much better results.
ErgoDox Classic Aluminium (MX Reds) | Leopold TKL Otaku (MX Browns) | Rosewill RK-9000 (MX Blues) | Dell AT101W (Alps Black)
Happily typing in Dvorak
Offline simon_C
« Reply #7 on: Mon, 17 October 2011, 02:36:06 »
hydrogen peroxide and a sprinkle of oxy clean did the trick for me.
Offline popol
« Reply #8 on: Mon, 17 October 2011, 02:49:26 »
Thanks to everybody.
There are 35% solutions of hydrogen peroxide for sale on ebay. Is it a too high concentration? Would a bottle of 500ml be enough?
I guess you put only white keys but HOW LONG did you do? ( I just have a peripheral yellow mainly touching a side of the keys)
Outside storage and transparent bowl closed?
« Last Edit: Mon, 17 October 2011, 02:52:22 by popol »
Offline enoy21
« Reply #9 on: Mon, 17 October 2011, 08:45:43 »
I have a further question about this after reading the Wiki and this specific method :
http://www.lemon64.com/forum/viewtopic.php?t=30892&start=75&postdays=0&postorder=asc&highlight=retrobright
Well a few questions really.
A: How does this effect the color of Double shots ?
B: How can you tell if it's yellowing with age or just it's natural color ?
C: This time of year in the mid Atlantic US it is cooler and less direct sun (UV) so would it still work ?
D: A heat lamp for a lizard.... Is that a UV lamp  ?
My thought is that I wouldn't mind using the double shots that are on my WYSE 60 but I really wanted a brighter white rather than an off white cream color.
http://geekhack.org/showthread.php?22293-Some-suggestions-on-a-mod-idea.....
11th post down.
WASD 104 work
WASD 104 home
WASD 104 [not my style]
Filco MJ2 Ninja 87 [sold]
Offline simon_C
« Reply #10 on: Mon, 17 October 2011, 15:32:58 »
Quote from: popol;432644
nope, 35% is good. just read the retr0brite page and youll know all you need to.
Quote from: enoy21;432711
11th post down.
A: wont matter. It will restore any abs to its original color.
B: try it and find out
C: pretty much any sunlight will work
D: wouldnt use a heat lamp, the reaction produces its own heat. Compact fluorescent  light bulbs work really well.
this does not change the original color of the keys. if they were cream to begin with, they will be restored to that original cream color. all it does is remove the yellowing caused by the bromine fire retardant.
Offline flyball
« Reply #11 on: Mon, 17 October 2011, 17:45:33 »
you use your keyboard outside?
[SIGPIC][/SIGPIC]
Offline enoy21
« Reply #12 on: Mon, 17 October 2011, 17:53:21 »
So ummmmmm no one told me that the oxy would continue to foam after going under the light.  I put it in a bowl on my computer desk and came back to a mushroom like topping threatening my new keyboard.  I see the oxidation working. Am I supposed to keep the foam off to allow the light to penetrate the liquid surface ?
Also is there any tricks to keeping the keys fully submerged ?  The bubble action keeps getting under them and raising them above the surface.
« Last Edit: Mon, 17 October 2011, 17:55:37 by enoy21 »
WASD 104 work
WASD 104 home
Offline StaCT13
« Reply #13 on: Mon, 17 October 2011, 19:35:24 »
When I whitened my keys, I used two clear plastic cups per 2 keys.
Place the first cup, place in 2 keys (or however many that fit easily upright), pour in Hydrogen Peroxide, place in second cup (to squish the keys), and rubber band the cups together. A bit tedious and the cups I used only fit 2 keys each, but it kept those things in place.
ALSO, please note that many clear plastics still block UV light. Check with a blacklight or something. If in doubt, I know plastic wrap doesn't.
Offline StaCT13
« Reply #14 on: Mon, 17 October 2011, 19:39:35 »
BTW, the process should take around 5-7 hours IF you use Oxiclean, nothing goes wrong, and the stain isn't all that bad. Otherwise, expect closer to a week to get a good result.
Offline enoy21
« Reply #15 on: Mon, 17 October 2011, 20:07:25 »
I'm ok with patience , but wasn't it determined that Oxy stops working after 6 hours ?  I have no lid on the container and the light is about 5" over top of it shining directly into it, but there are alot of bubbles still hanging around and the keys keep wanting to shift so I've been stiring it about every half hour for the past 2.5 hours. I really don't see much difference at the moment. I figure I'll leave it over night in the dark tonight and restart the process tomorrow. I just hope it's not a waste since it's not UV sunlight/lamp and they aren't all staying fully submerged facing directly into the light.
I didn't see anything in the threads about CFL until the last couple by Rip and someone else that was quite helpful and said about the same things he did.
WASD 104 work
WASD 104 home
Offline enoy21
« Reply #16 on: Mon, 17 October 2011, 20:20:30 »
I also think that when I do it tomorrow , I will use a shallow glass baking dish and try my best to keep the keys upright along the bottom using a second glass baking dish on top. Good call Stact.
WASD 104 work
WASD 104 home
Offline enoy21
« Reply #17 on: Tue, 18 October 2011, 07:50:41 »
So after about 3 hours in the plastic bowl I went ahead and transferred half the keys (The lighter ones) to the glass baking dish facing up, placed another glass baking dish on top to hold them in that position, then trickled in the oxy mixture until they were all covered well.   Stuck it under a CFL light for the night.   This morning they did indeed look brighter, but I haven't had time to compare them to the space bar that I left out of it as a control.
WASD 104 work
WASD 104 home
