Author Topic: Noppoo Choc Pro and Cherry POS board (both browns)  (Read 1824 times)
Offline N8N
  • Trade Count: (0)
« on: Sat, 15 October 2011, 12:18:26 »
So I bit the bullet and ordered a Leopold w/ clears because I wanted one.
In an attempt to be not quite so profligately wasteful, I offer for your consideration, a Noppoo Choc Pro (S/N 193) and a Rawko board w/ browns.
The Noppoo is as new save for having a set of WASD new process lasered keycaps on it in a Dolch/RGB color scheme.  The space bar has the posts added for Noppoo and Cherry boards, so it will fit Choc Pro as well as Filco, WASD, Das, and Cherry.  I still have all the original keycaps as well although the original space bar needs some minor repair as one of the stabilizer things appeared to have been glued in prior to my having acquired the keyboard, and I had to remove it to make a jig to modify the WASD space bar.
The Rawko board is cleaned and lubed, as I was using it as a switch try board.
Both boards have MX Brown switches.
I would like to get $90 for the Noppoo board without the WASD caps or $140 with.
I'd like to get $45 for the "rawko" board.
prices are w/o shipping...  I am in CONUS
thanks!
« Last Edit: Sat, 15 October 2011, 16:02:14 by N8N »
