Author Topic: Advice on Monitors ?  (Read 12480 times)
Offline Fobbah
« Reply #50 on: Mon, 31 October 2011, 02:48:50 »
Quote from: sinis;432701
Prad has a lot of tests and tables of monitor features that are good for comparison. Not so good if you only read one test for a standalone opinion.
Benq 2410t  is perfect!
24", FullHD, 120Hz, pivot function, height and angle adjustment, LED background, but slightly over 300€ per monitor.
It is my main monitor.
Totally agree, I have the same monitor and for some reason it's a lot less harsh on the eyes for reading text than any other monitor I've used. I'm not sure if it's a slight tint to the monitor, but i havn't been able to replicate it with my other screens and it's highly desireable if you spend a lot of time reading black on white. Definitely my go-to monitor if i had to replace one.
Offline cheeseds
« Reply #51 on: Sat, 05 November 2011, 01:49:57 »
This might have already been pointed out in this thread but it bears repeating pixel response time means very little, any more its simply a marketing term there is no industry standard for measuring grey to grey response time. a better measure is the ISO standard, black to white. TN panels have been stuck at 8 to 5 ms, VA panels around 12 and IPS panels around 12. unfortunately when was the last time you played a game where there is a quick succession of black and white frames?
[ Attachment Invalid Or Does Not Exist ] 30900[/ATTACH]
This is a graph of what actual response times look like on a TN panel, this monitor would probably be quoted at 10ms before overdrive
and that brings me to overdrive. Overdrive brings G2G into the picture
this technology is based on applying an over-voltage to the liquid crystals to motivate them into their orientation faster. This process forces them to a full white (inactive) to black (active) transition first. The crystals can then drop back down to the required intermediate grey level. This is helpful as the rise time of a liquid crystal was always the slowest part (response time = Tr + Tf). This technology does not help improve the ISO black > white transition much since that already received the maximum voltage anyway, but transitions from grey > grey are significantly reduced. The improvements in grey transitions however are helpful in producing a faster panel overall as these changes have always been slower colour changes in TFT panels and it is important that the response time is low across the whole range of transitions (0 – 255). Screens featuring  RTC will normally show an improved responsiveness in practice and reduced motion blur and trailing. Manufacturers will usually quote a "grey to grey" (G2G) response time figure on screens using this technology since they are normally the fastest transitions available. Look out for "G2G" quoted in the spec sheets.
of course this is a double bladed knife properly done overdrive works GREAT at reducing ghosting and blur, but poorly done overdrive add more pain then it solves
Example
good overdrive
[ Attachment Invalid Or Does Not Exist ] 30902[/ATTACH]
as you can see there are no artifacts around the car or speech bubble infact it looks as if its standing still, also note that this is a 120Hz TN Samsung
VERY BADLY DONE OVERDRIVE
[ Attachment Invalid Or Does Not Exist ] 30904[/ATTACH]
as you can see there are black artifacts almost 3 frames deep. this is a 60Hz TN BenQ
ALL QUOTES AND IMAGES TAKEN FROM http://www.tftcentral.co.uk
Offline cbf123
« Reply #52 on: Mon, 07 November 2011, 11:28:56 »
Quote from: iindigo;436454
Maybe you were fortunate enough to have high-end CRTs... the best I ever had was the one in my old 15" iMac from 2000 and a 17" Flat-faced Sony Trinitron, both of which had the problems previously described (though the Trinitron was a bit better in some respects).
I had a very nice Dell-branded Philips 19" shadow mask monitor that did 1600x1200 with beautifully sharp and clear text, then some very nice 21" Trinitrons at work.  When the 19" finally died after about ten years I jumped to a 24" 1920x1200 Dell LCD.  I need the 1200 vertical pixels though...1080 is just not enough.  The 2560x1600 30" that Dell sells looks awesome.
Daily drivers are:
Microsoft Natural (the original, and still going strong)
Microsoft Natural Elite
