Author Topic: Keyboard Failure! Help with troubleshoot?  (Read 2164 times)
Offline Glacierx
« on: Mon, 17 October 2011, 18:56:55 »
I recently purchased a mechanical keyboard by ThermalTake (Meka G1). After a few days, I started getting the "Keyboard Failure" during the boot-up phase. It asks me to press F1 or F2 to continue/configure bios settings, which is funny considering the keys don't work...
Anyway, reconnecting it to the USB seems fixes the problem, except the problem comes back when I boot into Windows, so I have to reconnect again. I have tried different USB ports, same problem. I never had this problem with a membrane keyboards, so I'm really confused as to why this is happening.
I have also flashed the BIOS to a newer version, but the problem persists when I boot into windows. I'm not sure what the next steps are...
I'd send this in for a replacement if I can somehow confirm it is a hardware issue...
Offline sinis
« Reply #1 on: Mon, 17 October 2011, 18:59:31 »
Is the failure reproducable on a different PC?
Offline pyro
« Reply #2 on: Mon, 17 October 2011, 19:01:09 »
Try replacing the USB-Cable with a different one.
Offline Glacierx
« Reply #3 on: Mon, 17 October 2011, 19:02:01 »
I have not tried this, I do have a laptop but it is rather inconvenient to set it up. This does NOT happen every time I boot up, which makes me think it might be hardware malfunction...
Offline Glacierx
« Reply #4 on: Mon, 17 October 2011, 19:03:02 »
Quote from: pyro;433182
The cable is not detachable..., it's one of those military grade cables with several outlets including sound and mic...
Offline Glacierx
« Reply #5 on: Mon, 17 October 2011, 19:17:27 »
Just tried it a bunch of times on laptop. Unplugging it and plugging it back in, 80% of the time it says device not recognized... I think this warrants for an exchange...
Offline StaCT13
« Reply #6 on: Mon, 17 October 2011, 19:20:48 »
I'd RMA it. That doesn't seem normal. Not a bad choice in board, though.
ErgoDox Classic Aluminium (MX Reds) | Leopold TKL Otaku (MX Browns) | Rosewill RK-9000 (MX Blues) | Dell AT101W (Alps Black)
Happily typing in Dvorak
