Author Topic: Engraved White KBC PBT 87/104 key set + Yellow Esc Key (CLOSE THREAD))  (Read 2076 times)
Offline c0rbin
  • Trade Count: (0)
Acquired.
« Last Edit: Sun, 23 October 2011, 20:00:00 by c0rbin »
Filco Majestouch-2 Tenkeyless Cherry MX Brown w/ PBT caps and O-ring mod
Offline delgo
  • Trade Count: (0)
« Reply #1 on: Fri, 21 October 2011, 18:28:19 »
Or just order the theme at wasd?...
Doubt that anyone have made a theme of what you want and then also is willing to sell it, fair price would probably be what wasd takes for theirs anyways soo.
(If you maybe didn't notice, you can remove the actual keyboard from the wasd custom keyboard design which should drop the price, also use only engraved keys or only lasered and not a mix of lasered and engraved..)
KB\'s: Filco TKL MJ2 Ergo Clear/Brown Swedish ISO, HHKB white blank, IBM Model M 1990 ISO
On the way:  Phantom!
Offline c0rbin
  • Trade Count: (0)
« Reply #2 on: Fri, 21 October 2011, 18:45:21 »
I'm trying to keep all the keys the same material just to be consistent... I already have a KBC PBT set. I believe WASD sells only ABS keys.
Worse comes to worse I will have to either do as you say and order from WASD or maybe even one of the group buys or go the expensive route and buy a whole set.
That said, I would think somebody would at least have a Yellow Escape key they are willing to sell...
Offline c0rbin
  • Trade Count: (0)
« Reply #3 on: Sun, 23 October 2011, 11:36:34 »
Okay, I have changed what I'm looking for. OP updated.
