Author Topic: Mac Keycaps  (Read 2885 times)
Offline ozziegt
Mac Keycaps
« on: Mon, 24 October 2011, 10:18:26 »
I just bought a Rosewill RK-9000BR (my first mechanical keyboard...:happy:), but it's for my mac at work. Does anyone know where I can get a set of mac keycaps or maybe even just get a blank key to replace the windows key?
Thanks
edit: And it looks like I posted my first post to the wrong forum...can someone move this to the proper sub forum?
Offline iindigo
Mac Keycaps
« Reply #1 on: Mon, 24 October 2011, 10:33:33 »
Das Keyboards sells Mac Keycaps, and WASD Keyboards sells blank and customized keys. Both are compatible with Costar boards, like your Rosewill.
Offline RColinTaylor
Mac Keycaps
« Reply #2 on: Mon, 24 October 2011, 10:35:29 »
There are a couple of options.
Das sells what they call a 'Mac Key Cap Set' which comes with Four mac-styled keys.
http://tinyurl.com/3hwolwe
You can also go the route of having WASDkeyboards.com have you make custom keys. iindigo had this SVG made for a custom set that he was considering: http://geekhack.org/attachment.php?attachmentid=29448&d=1319258366. Going this route costs ~$60 but would look amazing in my opinion.
Source:
http://geekhack.org/showthread.php?23203-Finishing-Touches-for-a-Layout
The third option I have for you comes from WASDkeyboards.com again and is their individual-key customizer:
http://www.wasdkeyboards.com/index.php/products/printed-keycap.html
There are other methods to getting mac-style keys but for what it sounds like you are looking for these will be the easiest.
EDIT:
iindigo beat me to it.
Quote from: iindigo;437963
I like my Browns more than my Blues.
Offline ozziegt
Mac Keycaps
« Reply #3 on: Mon, 24 October 2011, 10:48:28 »
Thanks for all the info. Kinda wish I had come across WASD before buying the Rosewill...it's too late for me to cancel now though. :ohwell:
Mac Keycaps
« Reply #4 on: Mon, 24 October 2011, 10:49:59 »
I bought a custom set from WASD for my Leopold; Rosewills are really, really good keyboards. You made the right purchase.
