Author Topic: Replace my ball mouse, please.  (Read 4323 times)
« on: Thu, 27 October 2011, 12:20:49 »
I've been using a dell ball mouse daily ('cause it's USB), and I really don't like it. I mean, it works, but It's awful.
The reason is, I can't find a my optical logitech, which is cheap, but worlds better.
Can anyone recommend a good, inexpensive mouse to replace it? I'll only need two clickbuttons, and a scroll wheel. I'd prefer a scroll wheel that I can click (to close tabs, etc.)
I'm using a stack of tektbooks as a mousepad, so laser/optical will probably be fine.
Use to be 'everyday' with 0% gaming.
Thanks in advance!
Offline pitashen
« Reply #1 on: Thu, 27 October 2011, 12:30:37 »
what is your price range? and what shape would you prefer?
Offline Internetlad
« Reply #2 on: Thu, 27 October 2011, 13:05:35 »
get yourself an inexpensive kensington mouse-in-a-box mouse. Dirt cheap,5 year extended warranty, works good, it's optical and does what you need.
http://www.amazon.com/Kensington-K72356US-Mouse--Desktop-Mouse/dp/B002ZIN9DU/ref=sr_1_2?ie=UTF8&qid=1319738553&sr=8-2
There's also a 15 dollar version, I have no clue what the difference is and have very little desire to learn, as i assume it's not worth the price increase.
http://www.amazon.com/Kensington-K72213USA-Mouse--Optical-72213/dp/B00025O7LQ/ref=sr_1_1?ie=UTF8&qid=1319738553&sr=8-1
I use several of these mice on a daily basis on my work bench and i've never seen one take a dump, use kensington keyboard-for-lifes too (hope that isn't blasphemy on geekhack) at work, they both work like champs.
For cheap ass periphs i can't reccomend em highly enough.
"Beep . . . Beep . . . Beep" -Sputnik I
« Reply #3 on: Thu, 27 October 2011, 17:55:45 »
Cool, thanks!
I especially like the warranty.
I'll probably also upgrade my gaming mouse, but not for a while at least.
« Reply #4 on: Mon, 07 November 2011, 06:15:24 »
Well, I ordered a mouse-in-a-box. I'm really getting sick of this godawful ball-mouse. Maybe I'll start doing tablet input exclusively.
Thanks for the input!
Offline Foodmanchew
« Reply #5 on: Tue, 08 November 2011, 00:39:27 »
I miss my ball mouse. It was always so satisfying taking it apart and cleaning the dirt off of the rollers inside.
« Reply #6 on: Tue, 08 November 2011, 18:44:14 »
Quote from: Foodmanchew;447850
You can have mine for $5.20 (shipping). It's a Dell USB, but I don't think it's worth it.
If you don't want it (good) I'll take the scrollwheel out and mount it to a VCR read head for an epic spinner. (Take THAT griffin powermate!)
Mouse-in-a-box came in. I love the packaging. It's bubblewrap in two sections (one for mouse, the other for the cord) crammed into a box with a tiny warranty card in it.
Still getting used to the higher DPI. I like the scrollwheel. Would buy again.
