Author Topic: Cherry MX Red Key Grittiness?  (Read 4280 times)
Offline Lethal Squirrel
  • I <3 60%
« on: Fri, 28 October 2011, 19:23:32 »
I just got my new KBC poker today and the key switches are kinda gritty. A lot less smooth than I imagined. I'm Basically wondering if the keys break in, and the grittiness goes away. I'm really liking the board though. Pretty much has all the functions of a normal keyboard. I was expecting to not be able to control alt delete and stuff like that.
« Last Edit: Fri, 28 October 2011, 19:29:44 by Lethal Squirrel »
Offline noodles256
  • le legendary
« Reply #1 on: Fri, 28 October 2011, 19:38:35 »
the pcb mounted feel 100% different than the plate-mounted ones. I personally don't like the pcb-mounted ones. The plate-mounted ones do feel like a cloud of boobs though
AF | Ducky YOTD |
Offline jpm804
  • KeyCap Assasin
« Reply #2 on: Fri, 28 October 2011, 19:40:16 »
I have a kBC  poker reds and they dont feel gritty( but I did buy it used, so not sure how many hours it was used before I got it) ... feel similar to my other reds, minus the plate. For me Browns is what I think of Gritty for reference...
REALFORCE|FILCO|HHKB|KBC POKER X|LEOPOLD|CM STORM|SIIG (GHSS)|IBM SSK
  • I <3 60%
« Reply #3 on: Fri, 28 October 2011, 19:51:26 »
They honestly feel as gritty as browns. maybe I'm crazy or something. BTW, how much different do plate mounted reds feel?
Offline jpm804
  • KeyCap Assasin
« Reply #4 on: Fri, 28 October 2011, 19:55:52 »
To me it feels a little bit more solid, but thats my opinion.
This from typing on my filco reds, cm storm and havent tried out my leopold reds yet but expect the same kinda feel.
Offline noodles256
  • le legendary
« Reply #5 on: Fri, 28 October 2011, 19:59:20 »
Plate-mounted definitely feels more solid. It feels "heavier" too. The pcb -mounted ones are VERY light.
BTW,
If you have facebook, Please click the link and like the picture. Trying to win a dorm Makeover contest, Thanks guys
http://www.facebook.com/photo.php?fbid=10150336691004022&set=a.10150336690779022.353935.6132634021&type=3&theater
AF | Ducky YOTD |
Offline jpm804
  • KeyCap Assasin
« Reply #6 on: Fri, 28 October 2011, 20:02:26 »
I'm wondering if the feel will change significantly once I sawp out the poker case to the aluminum one I ordered...hope to report some feedback on that when I get it.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #7 on: Fri, 28 October 2011, 22:28:48 »
I have a shiny new Leopold with reds and it is as smooth as butter.  I have also used pre-owned (ghetto) reds on a PCB mounted keyboard and they too were grittless.
Offline flyball
« Reply #8 on: Fri, 28 October 2011, 22:33:32 »
mcrip
[SIGPIC][/SIGPIC]
« Reply #9 on: Fri, 28 October 2011, 23:05:55 »
Maybe it's the plate, but my CMstorm reds feel smooth. Even my ancient WYSE 50 (black) keys are smooth-feeling. H'm. The browns are a little "gritty" on the way down, but I like that little bit of tactility, to remind me, though I bottom out less on the reds.
Offline mmmty
  • bang! bang!
« Reply #10 on: Fri, 28 October 2011, 23:13:47 »
Quote from: jpm804;441492
Kindda funny, the Poker red you got from me is the same one I got from noodles. I bought it for the clear caps.
Keyboardless
  • I <3 60%
« Reply #11 on: Fri, 28 October 2011, 23:19:57 »
I have a WYSE 50 too and I was gonna mention the smooth keys on it :o
  • I <3 60%
« Reply #12 on: Fri, 28 October 2011, 23:22:11 »
So why would the surface the switches are mounted to have any effect of the smoothness of the key stoke? Unless we are talking about different types of grittiness?
Offline Lanx
« Reply #13 on: Sat, 29 October 2011, 00:26:03 »
are you talking about like the feeling of sand in the switch? (exaggeration) ghetto reds were smooth for me, pcb.
  • I <3 60%
« Reply #14 on: Sat, 29 October 2011, 00:49:27 »
yeah I am talking about that. but I really cant see how it being mounted on PCB rather than a metal place has anything to do with that.
Offline TheProfosist
  • Custom Layouts Only!
« Reply #15 on: Sat, 29 October 2011, 04:01:17 »
wait a week or 2 of constant use if it still feels gritty yopu could lube. I had this problem with my Rosewill keyboards.
fossala
  •  Guest
« Reply #16 on: Sat, 29 October 2011, 05:10:59 »
I have posted the same thing on deskthority about my new poker with browns. I was told that they will wear in.
Offline duncan
« Reply #17 on: Sat, 29 October 2011, 06:32:57 »
Quote from: TheProfosist;441680
+1
I have a Poker MX Red and it was smooth as from day one. Add an o-ring mod and maybe a hundred hours of typing later and it is still fine with no grit for me. Sorry your experience hasn't been as pleasant.
Realforce 86UB || HHKB P2 || FILCO MT 87 Blues || FILCO MT 87 Browns || FILCO MT 87 Ninja  Blacks || Poker X Reds
Offline slueth
« Reply #18 on: Sat, 29 October 2011, 14:22:38 »
Just got my CMStorm quickfire with reds.  There is some friction, but it is pretty smooth.  Hardly noticeable when you type fast, but like in another post, keycap material and speed of typing can lessen or exaggerate this.
Offline Zhuni
« Reply #19 on: Sun, 30 October 2011, 02:03:46 »
I got the KBC poker red....yes they wear in over time and become butter smooth. I got a filco red as well and they are both as smooth as each other. I prefer the KBC poker though for size mainly.
[sigpic] [/sigpic]
KBC Poker
fossala
  •  Guest
« Reply #20 on: Sun, 30 October 2011, 04:11:08 »
Just to let you know my browns are starting to wear in a little bit. There not perfect but there getting there.
