Author Topic: Poker leds.  (Read 1928 times)
fossala
  •  Guest
Poker leds.
« on: Sat, 29 October 2011, 06:24:20 »
Does anyone here know the specs of the leds in the poker? I am looking at replacing them with red ones.
Offline TheSoulhunter
  • ~ BOOO ~
Poker leds.
« Reply #1 on: Sat, 29 October 2011, 08:36:50 »
Blue LEDs typically need more juice (3.2-3.6v), so you have to add resistors...
A Ghost From The Past
fossala
  •  Guest
Poker leds.
« Reply #2 on: Sat, 29 October 2011, 08:47:14 »
Thanks, what would happen if I didn't. Would it just be bright or would it blow the led? From something I read on hard form I am lead to believe the blues are only running at half brightness.
Offline Soarer
Poker leds.
« Reply #3 on: Sat, 29 October 2011, 08:56:35 »
Quote from: TheSoulhunter;441737
For a higher forward voltage you actually need a lower resistor value to get the same amount of current flowing.
edit: reread, and found that's exactly what you were saying :)
« Last Edit: Sat, 29 October 2011, 09:02:41 by Soarer »
Offline Lolcakes
Poker leds.
« Reply #4 on: Sat, 29 October 2011, 08:59:51 »
It will be brighter and possibly die earlier. If you have a multimeter you can measure the voltage and current and find the appropriate LEDs on ebay (=
fossala
  •  Guest
Poker leds.
« Reply #5 on: Sat, 29 October 2011, 09:04:30 »
I have a multimeter but I don't know how to use it.
fossala
  •  Guest
Poker leds.
« Reply #6 on: Sat, 29 October 2011, 09:52:18 »
It is back in one piece now. I will take it apart again when I receive the clear stems from BINIRIS.
