Author Topic: Poker KBC General thoughts + Slight issue.  (Read 1876 times)
Offline Shuki
« on: Mon, 31 October 2011, 00:36:49 »
Ordered one of these recently, wanted to try out a minimal layout board as well as cherry blues.. I must say I'm pretty impressed by both. I think cherry blues are my favourite switch of the ones I have tried. Blacks, reds, brown and topre are all nice switches but I feel the feedback on the blues is more suited to me. Plus they sound great while typing. I got the PBT keycaps, which I must say are a lot better than the filco keycaps as they have a slight texture on the top. My filcos keycaps always seemed to get shiny and slick quickly and they irritated my fingers. When I got the Topre I found it hard to switch between boards because the keycaps on it were so superior, but the ones on the KBC are pretty decent.
The only real gripe with this keyboard is the fact that ` and Esc share a key. As I play a lot of games in which ` is the console key by default and escape is pretty esential in general usage. Having only the ability to use one without having to change function seems to be quite irritating. I was thinking of possible solutions, I think the left windows key can be remapped to a secondary function key with the dip switches, however I kind of use the windows key frequently when tabbing in and out of games and the right windows key will sometimes be set to arrow keys. I was considering remapping a random key to escape as well but that also seems less than ideal. Anyone any suggestions?
Offline sordna
« Reply #1 on: Mon, 31 October 2011, 01:11:17 »
I map the Menu key to ` and ~ since I don't need Menu anyway (Linux user) although even in Windows, Menu can be substituted by Ctrl-Esc if I'm not mistaken.
Anyway, you can find a discussion relevant to this subject here:
http://geekhack.org/showthread.php?22474-Linux-vim-and-the-Poker-s-escape-tilde-combination
Offline Shuki
« Reply #2 on: Mon, 31 October 2011, 01:16:14 »
Is the menu key the key next to the right windows key?
Thanks for the link, didn't see it before (not that I didn't search or anything :p ).
Offline Shuki
« Reply #3 on: Mon, 31 October 2011, 01:36:53 »
Hmm perhaps the best solution for me would be using the dip switch to change the left windows key to fn and then just use space + fn on the occasions I would want to use the windows key.
fossala
  •  Guest
« Reply #4 on: Mon, 31 October 2011, 03:54:28 »
Quote from: Shuki;442536
All fn+space will do is activate the up-down-left-right arrows isn't it?
Offline Shuki
« Reply #5 on: Mon, 31 October 2011, 06:13:15 »
In this case deactivate it so that I am able to use the windows key as the right-windows key has been remapped.
fossala
  •  Guest
« Reply #6 on: Mon, 31 October 2011, 06:30:08 »
Ahh, I get you now. Sorry I have the same setup with only one windows key but I don't have my arrows locked.
Offline JustCallMeCrash
  • ErgoDox Lover
« Reply #7 on: Mon, 31 October 2011, 08:44:01 »
Shuki:  Nobody really needs the CAPSLOCK key...just remap that to be your `/~
I generally just disable that one since I hate accidentally turning it on.
ErgoDoxen 6 total: Cherry MX Browns, Cherry MX Clears, NovelKeys Box Royal, 80g Gateron Yellows, NovelKeys Pale Blues, NovelKeys Box Navy.
Preonic 2 total: OG Gateron Yellows (GMK silencer clips), TBD (unassembled v2).
XD-75 (mixed Gateron Yellows, MX Blacks, MX Clears on layer toggles).
Das S Professional (was MX Blues, now Ghetto Reds).
G80-11900.
ML-4400 (2x) Cherry MY boards.
Offline itlnstln
« Reply #8 on: Mon, 31 October 2011, 08:47:17 »
Quote from: JustCallMeCrash;442591
Speak for yourself, homie.  My Caps Lock gets well exercised.
