Author Topic: What's up with my RK-9000  (Read 2348 times)
Offline RetroHollywood
« on: Mon, 31 October 2011, 13:37:05 »
I purchased a Rosewill Rk-9000 (with blues) and have been having some "issues" with it, and am trying to decide if they are serious enough to return it.  I thought the experts here would know if they were common, serious, my imagination, etc.
Problems:
-Right shift key feels different from all other keys, more specifically a bit spongier.  Removed and lubricated stabilizer and tested switch pressure (normal).  No change.
-Spacebar squeaks like crazy.  Heavily lubricated stabilizers.  No change.
-Arrow keys all have different pressures, including on the switches themselves.
Anything I can do to remedy these?  Is the keyboard flawed?  Are my expectations just too high?
Offline itlnstln
« Reply #1 on: Mon, 31 October 2011, 13:41:19 »
How long have you had it?  Sometimes you need a week or two to break the switches in, especially blues from what I understand.  I have had the spacebar squeak on a few Costar 'boards; I'm surprised lubing it didn't help.  Did you lube up by the cap?
Offline Lanx
« Reply #2 on: Mon, 31 October 2011, 13:45:54 »
i've fixed some used keyboard keys by banging them in with the butt end of the screwdriver, of course the barbarian approach doesn't work well all the time (now i just desolder and put in fresh switches).
« Reply #3 on: Mon, 31 October 2011, 13:46:15 »
I have had it for about a week, with pretty heavy use.  I've probably put about 20-30 pages through it, plus normal internet forum use.
I really went after the spacebar.  Anywhere the stabilizer bar went, I put lube there.
Offline itlnstln
« Reply #4 on: Mon, 31 October 2011, 13:48:55 »
I wonder if it was damaged in shipping and has a bent plate or something.  I would see about sending it back.
Offline noodles256
  • le legendary
« Reply #5 on: Mon, 31 October 2011, 13:56:25 »
looks like you used all 10 milllion actuations
sorry
AF | Ducky YOTD |
Offline c0rbin
« Reply #6 on: Mon, 31 October 2011, 15:26:08 »
Speaking of actuations... what exactly wears out to warrant most Cherry MX switches being rated for only 50 million presses?
Filco Majestouch-2 Tenkeyless Cherry MX Brown w/ PBT caps and O-ring mod
Offline itlnstln
« Reply #7 on: Mon, 31 October 2011, 15:28:45 »
I think it's just a SWAG.  Probably corrosion or reduced springiness on the contacts or something.  Chattering has been observed by some.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #8 on: Mon, 31 October 2011, 15:29:47 »
carbon forming on the contact points from arcing might impede the switch from actuating after that many.  Otherwise it's really just the tactile switches wearing.  I know I've had microswitches fail from carbonization.
Filco w/ Imsto thick PBT
Offline itlnstln
« Reply #9 on: Mon, 31 October 2011, 15:32:56 »
I wonder if anyone has ever hit 50 million + on a Cherry switch (other than a machine).  I would imagine most people would replace a keyboard for other reasons before the switches actually start to malfunction.
Offline LaneWeaver
« Reply #10 on: Mon, 31 October 2011, 15:44:02 »
Regarding the spongy right shift key, I too had this problem. I ended up swapping the stabilizer out from another key (the '+' key on the numpad) and the issue went away. It had something to do with the stabilizer not collapsing all the way - it was collapsing into the base of the switch.
Filco Majestouch 2 TKL | Razer BlackWidow
