Author Topic: Phantom Custom Keyboard Group Buy (CLOSED)  (Read 472438 times)
Offline bpiphany
« Reply #250 on: Tue, 15 November 2011, 12:11:01 »
Quote from: Findecanor;452645
Shouldn't the drill hole for the ISO Left Shift be slightly to the right? It should align precisely with the Left Ctrl and Caps Lock, I think.
That is one of the slots... You can see the extent of the slots on the copper. And that copper oval extends to the correct location =)
Offline Wraul
« Reply #251 on: Tue, 15 November 2011, 14:42:34 »
I think this might have been asked previously, unfortunately I cant find it now though. Sorry for asking again if that's the case.
Will the ISOWIN plate have extra holes in the right section like the 7BIT plate?
It would be nice to have sort of a semi numpad.
Offline bpiphany
« Reply #252 on: Tue, 15 November 2011, 14:44:54 »
Quote from: Wraul;452769
Yes all plates will have the extra cutouts above the arrow cluster. Please note that they will not be accessible with the Filco case, at least not without cutting into it...
Offline 7bit
  • MX1A-G1DW
« Reply #253 on: Tue, 15 November 2011, 14:48:54 »
Quote from: PrinsValium;452772
[size=8]Congratulations!
You've posted the 256th post in this thread!
You won a Phantom PCB![/size]
[/color]
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline Wraul
« Reply #254 on: Tue, 15 November 2011, 14:51:41 »
Thanks. Now I'm happy :)
Quote from: 7bit;452776
Congratulations!
And now I'm sad for missing that free PCB by one post :(
Offline bpiphany
« Reply #255 on: Tue, 15 November 2011, 14:59:24 »
Quote from: Wraul;452778
Either that was an automated response, or he's just pulling your leg.. I will have a PCB anyways =P
Offline tsangan
  • 1000/600
« Reply #256 on: Tue, 15 November 2011, 15:06:43 »
7bit is definitely trolling :fish:
Keyboardless
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #257 on: Tue, 15 November 2011, 15:08:51 »
And PrinsValium has one more bit than 7bit.  PrinsValium, you are now known as 8bit.
8bit -> 256
Offline Wraul
« Reply #258 on: Tue, 15 November 2011, 15:16:43 »
Quote from: PrinsValium;452784
Grrr 7bit is such a bully :)
Offline bpiphany
« Reply #259 on: Tue, 15 November 2011, 15:40:34 »
I actually turned 6bit in September, and made a big thing about it. I became "jämnjämnjämnjämnjämngammal" ("jämn"=even/round, "gammal"=old). We usually say we turn a "round numbered" age at 25, 40, 50 so on, I think that is what is called a round number in English. The Swedish word four "round" and "even" is the same. So it is a little nerdy to make a big thing about turning 32 =D We also build longer words by writing short ones together. A skipping rope is a "hopprep", "hopp rep" would be nonsense in Swedish.
Offline 7bit
  • MX1A-G1DW
« Reply #260 on: Tue, 15 November 2011, 15:44:21 »
But now, you officially won one!
I hope you appreciate it!
So you are now a hundred thousand years old.
Impressive age you've got!
BTW:
Hopprep sounds much more like what it really is. Don't get what they skip with it.
« Last Edit: Tue, 15 November 2011, 15:51:06 by 7bit »
Offline Autolyze
« Reply #261 on: Tue, 15 November 2011, 22:09:24 »
I'm still torn on this. Anyone want to convince me to get a 7bit layout Phantom or to pass this time?
Including a Poker I'm waiting on from the current Poker group buy, I've picked up seven mechanical keyboards in the last four months. I told myself and numerous friends that I was going to hold off on more keyboards for a few months, but... I don't normally have a chance to get a programmable keyboard with a ridiculous number of keys in a standard tenkeyless size. I'm cool with screwing around with the Teensy firmware, but I don't have a good way of doing much with the hardware-side of things.
Would it be practical to do a Phantom without a cover plate, seeing as how there probably won't be one that's compatible with the 7bit layout? Or does anyone have any particular plans about what they'll be doing in terms of cases for 7bit boards?
Offline kps
« Reply #262 on: Tue, 15 November 2011, 22:50:43 »
Quote from: Autolyze;453011
Don't forget you can also go over to Round 4 to get interesting and useful caps for that ridiculous number of keys.
It seems to me that if you stuff the latest PCB full of keys, the top cover becomes ridiculously simple:
Offline TheProfosist
  • Custom Layouts Only!
« Reply #263 on: Wed, 16 November 2011, 01:11:51 »
Quote from: PrinsValium;452580
All talk and no business!! But now at least it is official I have no life... I added the extra switch locations to the function row that 7bit requested. Had to ditch the helper-holes for F5-F8 (who is going to hot swap their F-key stems anyway?). Did some icky rerouting and got all switches attached to the electrical wiring. So no jumper wires will be necessary (the logical matrix locations of the extra two keys are a bit off though).
I think stem change should be possible even without the holes (if it works at all..) It should be possible to get them open like this The holes in the PCB are only there to make it a bit easier. Myself I wouldn't mind dropping all the quick-stem features to have a cleaner board and plate, but that isn't up to me... =P
Teaser! White round things are holes, slots doesn't render correctly as usual...
does this mean that extra switches can be put in the function row?
Quote from: PrinsValium;452808
Would a well designed layout convince you? http://tinyurl.com/d9lqxwr
Quote from: kps;453030
I would like to confirm if thats what the new PCB looks like as well because then I have more to work with and I am going to have to update my layout.
Also anyone have any ideas yet on a case for the 7bit layout? I dont need something as nice as a filco case but at least something so theres not just a PCB sitting on my desk and have the ability to move it without it all coming apart.
« Last Edit: Wed, 16 November 2011, 01:31:21 by TheProfosist »
Offline 7bit
  • MX1A-G1DW
« Reply #264 on: Wed, 16 November 2011, 02:21:25 »
Quote from: TheProfosist;453070
My recommendation is still to just get a backplate, wood or metal from the mount-plate manufacturer.
Maybe some thing to cover the sides as well. Bute surely, there is no need to have cover plate for this.
It is not like you look at the naked PCB. There is a cover already (the mount plate).
« Last Edit: Wed, 16 November 2011, 06:19:51 by 7bit »
« Reply #265 on: Wed, 16 November 2011, 02:42:53 »
Quote from: 7bit;453103
It is not like you look at the nacked PCB. There is a cover already (the mount plate).
The back and possibly sides would be great, it would be even better if it screwed in and kept the basic angle that keyboards normally have. And I agree there is no need for a cover plate because the mounting plate is already there.
Offline 7bit
  • MX1A-G1DW
« Reply #266 on: Wed, 16 November 2011, 06:20:46 »
Offline Tarkoon
« Reply #267 on: Wed, 16 November 2011, 06:58:32 »
It would be enough if the mounting plate wo be about 25cm longer to the front, then you could just fold it to the back and use it as stand. And the angle of the keyboard would be adjustable too with that!
Just like a >
And if you like your keyboard a little bit higher you could just fold it two times in the front.
This way height and angle would be adjustable.
Edit: Or fold again up the last few cm in the back to nearly close the backside of the keybard. (with a gap for the cable)
All that would look really clean and do a great job as case - a little bit like the corair keyboard... ;-)
Edit2:
This company ( http://www.schaeffer-ag.de/index.php?id=8&L=1 ) would also be a possibility to get the plates at a good price. I know many people getting individual pc case fronts from there...
I would offer to create a case with their design tool in a few hours at home.
How thick must a plate for plate mounted MX be? (minimum and maximum please)
« Last Edit: Wed, 16 November 2011, 07:28:01 by Tarkoon »
Offline alaricljs
  • I be WOT'ing all day...
« Reply #268 on: Wed, 16 November 2011, 07:37:58 »
Everything you ever wanted to know about switch dimensions is here.  But the quick answer is .06 +- .004 inch.
Filco w/ Imsto thick PBT
Offline Tarkoon
« Reply #269 on: Wed, 16 November 2011, 07:51:34 »
Uh, I just saw they increased their prices in the last years... =(
A full "case" as I described it would be be about 100€.
5-9 = 90€
10-19 = 80€
20-29 = 70€
So BiNiaRiS vendor seems to be much cheaper.
Perhaps he can just add the material to the front side of the plate...
« Last Edit: Wed, 16 November 2011, 08:31:00 by Tarkoon »
« Reply #270 on: Wed, 16 November 2011, 08:15:27 »
Quote from: 7bit;453157
looks like that answers my question about weather the pcb has been updated and is capable of more switches.
Quote from: alaricljs;453176
I would say make the plate as thick as you can (within the specifications of course) as thicker plates feel studier.
Quote from: Tarkoon;453182
5-9 = 90€
10-19 = 80€
20-29 = 70€
Perhaps he can just add the material to the frint side of the plate...
If your going to do something like that do something like what was done with the DOX keyboard
« Last Edit: Wed, 16 November 2011, 08:22:22 by TheProfosist »
« Reply #271 on: Wed, 16 November 2011, 08:17:14 »
Offline kps
« Reply #272 on: Wed, 16 November 2011, 08:58:26 »
Quote from: Tarkoon;453166
If you're in North America, the really quick answer to take to your local metal vendor is 1/16 inch.
Offline alaricljs
« Reply #273 on: Wed, 16 November 2011, 09:03:59 »
Nevermind... decimal point failure... brain crashing.
Offline Tarkoon
« Reply #274 on: Wed, 16 November 2011, 09:08:35 »
Quote from: kps;453208
I'm in Germany, so I had to convert it to 1,5mm... ^^
« Reply #275 on: Wed, 16 November 2011, 09:21:01 »
When I turned 32, I used to say that I turned 25. I thought you were 25 (decimal) or so years old.
Offline Dezeer
« Reply #276 on: Wed, 16 November 2011, 09:51:53 »
I sent on order PHISOWINREDKIT 1, but I got an empty receipt, is the normal PHISOREDKIT with or without WIN backplate?
Offline bpiphany
« Reply #277 on: Wed, 16 November 2011, 10:18:32 »
Quote from: Findecanor;453225
Yes, I do look young and firm, don't I? =)
Offline HaveANiceDay
« Reply #278 on: Wed, 16 November 2011, 12:11:03 »
Quote from: PrinsValium;453251
Such a stud!
Filco Tenkeyless Brown with beige cherry doubleshots (home)
Realforce 86U (work)
Get you own Phantom NAO!
Offline litster
« Reply #279 on: Wed, 16 November 2011, 13:10:30 »
We are for rEaLz, ripster!  :D
Well, the PCB and the plates for sure.  Still waiting for Cherry switch quotes from Germany.  We Kaiserriech found a source in China who can also get use switches and sounds like there is no minimum order, but most likely at a higher price.  Stabilizers remain to be elusive.  Worst case would be to source them from used G80 POS keyboards on ebay.  That's actually the cheapest way to get switches and stabilizers.  No one seems to have spacebar stabilizers of any size though.  In fact, no one can source costar stabilizer metal wires.
Offline Autolyze
« Reply #280 on: Wed, 16 November 2011, 20:00:51 »
Okay, screw it, I'm going for it. PMing Phantom now with this order:
TEENSY 1
PHANTOM 1
PH7BIT 1
MXCLEAR 105
DIODE 125
LEDBLUE 2
BACKPLATE 1
BACKSCREWS 1
PHANTOMFUN 1
SOLDERING 1
Let me know if anyone sees any horrific problems with that.
How many LEDs would this easily support anyway? I don't plan on using the standard caps/scroll lock setup, but I'd like to use them to indicate different layers and/or other fun things that come to me.
Edit: Depending on what the switch prices end up looking like, I might also be down for some blue switches.
« Last Edit: Wed, 16 November 2011, 20:05:07 by Autolyze »
Offline litster
« Reply #281 on: Thu, 17 November 2011, 00:59:11 »
Dox made his custom keyboard and he did something similar to what you suggest:  http://geekhack.org/showwiki.php?title=Island:19227
« Last Edit: Thu, 17 November 2011, 01:01:32 by litster »
Offline RColinTaylor
« Reply #282 on: Thu, 17 November 2011, 01:04:47 »
I have always looked at this project as an organized, and therefore cheaper, version of the Dox with some more complex aspects and possibilities.
I like my Browns more than my Blues.
« Reply #283 on: Thu, 17 November 2011, 01:17:50 »
Quote from: litster;453781
Yes, I did bring this up before but no one said anything. I think that it is a fine idea, we need someone to design it though and one person to be the guinea pig and pick one up to test it out and work out all of the kinks.
Quote from: RColinTaylor;453787
Same here, though I am also going to build a DOX since I have that almost worked out.
Offline litster
« Reply #284 on: Thu, 17 November 2011, 01:33:48 »
Quote from: TheProfosist;453799
I don't know how much Dox's keyboard is going to cost, but I don't think Phantom would be much cheaper, if at all.  Phantom uses more switches, more keycaps, has a high grade PCB, a PCB design that supports very many different configurations, and multiple versions of mounting plates.  I do hope we can drive down the price as much as possible.  I don't know how BiNiaRiS found a shop that can get plates done so cheap.  I checked with a couple of shops close to me and they both want at least 4 times as much as BiNiaRiS's quote.  The final price is going to depend on how cheaply we can source all parts.
The 4 of us have already put in seed money to start this, and we will need to put in a few hundred dollars for prototypes before we can start collecting money from you group-buyers to get final parts.  and potentially not get the seed money back if the plan doesn't come together.  Just like Dox and other people who build their custom keyboards, we do it for the fun of it.
« Reply #285 on: Thu, 17 November 2011, 01:37:32 »
A Dox board can cost around $300 in the end; everything is bought in non-bulk and therefore showroom prices.
Offline litster
« Reply #286 on: Thu, 17 November 2011, 01:40:51 »
They also need switches, right?  Maybe we can combine their switch orders with ours to bring up the volume and lower the price.
« Reply #287 on: Thu, 17 November 2011, 01:42:16 »
A Dox is more of an individual type project; I don't think there is a Dox group buy or anything going on. Dox just put up his custom board and instructions on how to do it/where to get everything and a rough price of what it will cost.
Offline litster
« Reply #288 on: Thu, 17 November 2011, 02:01:06 »
Well, if timing works for the Dox builders, they can just order switches from the Phantom group buy.
« Reply #289 on: Thu, 17 November 2011, 02:05:40 »
Quote from: litster;453817
I was planing on getting my switches for my DOX through this order if that is ok
Quote from: RColinTaylor;453819
that is the case 2-3 of us are doing builds but their all somewhat different
Quote from: litster;453834
that would be great! I plan to add my phantom order along with the needed parts for the dox once we finish working things out as we have changed much of the original plan for the better.
Offline ishtob
« Reply #290 on: Thu, 17 November 2011, 02:16:03 »
yup im planning on ordering some switches for my DOX project too, also probably going to build a phantom for my GF... just hope it can be before christmas... Was going to give her my 2 DOX boards I got so far, but she insisted on having those F#'s
Offline litster
« Reply #291 on: Thu, 17 November 2011, 02:23:06 »
It is unlikely, if not impossible, to get it shipped and received before Christmas.  We would be lucky to have 1 prototype done before the new year.  If we are lucky, we might be able to order the first 2 test PCBs 2 weeks from now.
You need to starting thinking about your Christmas gift backup plan :-)
« Reply #292 on: Thu, 17 November 2011, 02:44:12 »
Quote from: litster;453849
well thats actually good for me so that I can get cash together.
Offline ishtob
« Reply #293 on: Thu, 17 November 2011, 02:54:50 »
k thanks for the heads up!
Offline 7bit
  • MX1A-G1DW
« Reply #294 on: Thu, 17 November 2011, 03:10:16 »
Quote from: TheProfosist;453837
Yes, carry on! Order more!
Maybe I really should set up a switch group buy thread.
Code: [Select]
PHANTOM..........45
TEENSY...........36
PH7BIT...........12
PHANSI...........18
PHANSIWIN.........8
PHISO.............2
PHISOWIN..........5
BACKPLATE.........1
BACKSCREWS........1
DIODE..........2511
LEDBLUE...........4
MXBLACK.........566
MXBLUE..........188
MXBROWN.........768
MXCLEAR.........979
MXGREEN..........28
MXGREY...........22
MXRED...........710
STAB200..........40
STAB400...........5
STAB625...........3<-------------------no 6.25 units stabilisers found yet.
STAB700..........10
CASE..............6<-------------------no case currently
PHANTOMFUN........8
SOLDERING.........5
Offline Dezeer
« Reply #295 on: Thu, 17 November 2011, 04:01:46 »
Quote from: Dezeer;453236
7bit, why do you ignore me?
Offline bpiphany
« Reply #296 on: Thu, 17 November 2011, 05:03:11 »
I did a test of the firmware just now. Turns out I only have more or less broken Teensys (don't worry, I've treated them exceptionally bad to break them...). All except the two pins used for col0 and col1 worked. It seems like I got the firmware correctly, even the LEDs seem to be hooked up in the right order =) In the picture I have shorted row5 and col16.
[ Attachment Invalid Or Does Not Exist ] 32276[/ATTACH]
Offline 7bit
  • MX1A-G1DW
« Reply #297 on: Thu, 17 November 2011, 06:52:57 »
Quote from: Dezeer;453880
I will take care of it!
Quote from: PrinsValium;453891
(Attachment Link) 32276[/ATTACH]
Are these the key codes, the keyboard will send?
Code: [Select]
#define KEY_CTRL        0x01
#define KEY_SHIFT       0x02
#define KEY_ALT         0x04
#define KEY_GUI         0x08
#define KEY_LEFT_CTRL   0x01
#define KEY_LEFT_SHIFT  0x02
#define KEY_LEFT_ALT    0x04
#define KEY_LEFT_GUI    0x08
#define KEY_RIGHT_CTRL  0x10
#define KEY_RIGHT_SHIFT 0x20
#define KEY_RIGHT_ALT   0x40
#define KEY_RIGHT_GUI   0x80
What about KEY_E and KEY_GUI?
edit: At least for the keycode question I've fund an answer:
quadibloc.com/comp/scan
What does the modifier flag do?
Code: [Select]
const uint8_t is_modifier[NKEY]
Do I need to specify it true for all keys which I intend to use as modifiers?
« Last Edit: Thu, 17 November 2011, 07:27:23 by 7bit »
Offline bpiphany
« Reply #298 on: Thu, 17 November 2011, 07:26:11 »
Yes, you need to specify if the key is a modifier or not. They are handled very differently. All, eight, modifiers are sent as a single bit of the same byte in the protocol. Then there are 6 more bytes for the 6KRO keys sent in every HID package, they are stored one per byte. Setting the wrong flag in is_modifier gives rise to some very interesting bugs =)
Offline 7bit
  • MX1A-G1DW
« Reply #299 on: Thu, 17 November 2011, 08:22:24 »
Quote from: PrinsValium;453922
So there is a code for each modifier as a key plus the modifier flag?
If not:
I see the modifiers get numbers 1, 2, 4, 8, 16, 32, 64, 128.
These are for Shift, Alt, Control and Super (GUI)
What about the rest of the modifiers?
There are Meta and  Hyper which would require numbers 256, 512, 1024 and 2048.
