Author Topic: TAKUMI 10 Key USB Calculator - $40 (USA) $34 (Europe) shipped  (Read 7436 times)
Offline bootstrap
    • epiguru.com - My Personal Website
« on: Wed, 02 November 2011, 04:23:46 »
While waiting for my Model M SSK aka Snooki to arrive, I've been searching for a keypad with independent Num Lock function.
I came across this USB calculator:
http://www.ebay.com/itm/110763124915?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_500wt_1156
Designed in Japan, it looks interesting. You don't have to worry about independent Num Lock function because the arrow and numeric keys are separate.
But I probably won't get it because I prefer a more conventional design with the large '0' and 'Enter' keys. And I also like beige or red better. This seller has it only in black and white. If you don't mind either color, the price is quite attractive, especially for folks in Europe. The seller needs to build his/her eBay profile but the item is covered by eBay's Buyer Protection program.
You can read Ripster's write-up on this device here.
I just did a quick search. You can get this item from here too, shipping to a US address is about $7. Not much, something like a 17% difference in price.
The Best WordPress Theme Ever | Kinesis Contoured Model 100 | IBM Model F 1387033 "Space Unsaver" | CH Products DT225 Trackball x 2
« Reply #1 on: Wed, 02 November 2011, 08:39:37 »
Wow, thanks. I'd wanted one of these, but was driven away by the absurd pricetag (like $100) $40 is much more reasonable.
Offline tsangan
  • 1000/600
« Reply #2 on: Wed, 02 November 2011, 10:24:21 »
No red one ;(
But good price though
Keyboardless
Offline bootstrap
« Reply #3 on: Wed, 02 November 2011, 11:14:58 »
Glad to add value to the Geekhack community :)
fossala
  •  Guest
« Reply #4 on: Wed, 02 November 2011, 11:22:16 »
Does this work as a numpad as well?
Offline bootstrap
« Reply #5 on: Wed, 02 November 2011, 14:37:27 »
Quote from: fossala;444132
Yes, it works as a numpad if connected to your computer via USB. Disconnected (and with batteries), it works like a normal calculator.
http://global.rakuten.com/en/store/freedesign/item/idttc001/
Offline sordna
« Reply #6 on: Wed, 02 November 2011, 14:58:17 »
I have a black one, it's nice but the number keys don't auto-repeat, so if you use it for arrow keys or gaming you might be disappointed.
« Reply #7 on: Wed, 02 November 2011, 18:22:54 »
Quote from: sordna;444313
Oh really? That's uncool. Is there any way to make them? Maybe I'll just have to teensy it.
Offline sordna
« Reply #8 on: Wed, 02 November 2011, 19:45:48 »
I tried kbdrate and xset on linux but it didn't help. Then by using xev I found out that pushing a key down produces both a keypress AND a keyrelease event, even if you hold the key down :-(
« Reply #9 on: Wed, 02 November 2011, 21:16:27 »
Still, It looks like it's an awesome calculator, and will make a decent tenkey.
Offline sordna
« Reply #10 on: Wed, 02 November 2011, 21:24:42 »
Yeah, it's good, and mac/windows switchable. For Linux I'm using the mac mode, because the windows mode has the laptop trick which "pushes" NumLock instantaneously for every number keypress. Useful for laptops (whose numlock makes half their keyboard produce numbers) but not for desktops.
Offline kraise
« Reply #11 on: Wed, 02 November 2011, 23:24:24 »
Pretty sweet and the price is decent.
Keyboards: Filco Majestouch Linear R TKL | Matias Tactile Pro 3 LE Silver & Black | Matias Quiet Pro
