Author Topic: What's So Bad About Bottoming Out?  (Read 7059 times)
Offline Lethal Squirrel
  • I <3 60%
« on: Fri, 04 November 2011, 13:39:38 »
I always hear people say how terrible bottoming out is, and how you should try to not do it. But honestly, I really like the sound of bottoming out. I gives me a sense of quality and difference over rubber domes. I don't get why anyone would want to put dampeners on their keycaps the get rid of the solid sound and feel.
I'm not trying to sound like a troll or anything. This is just something that I've been thinking about ever since I joined geehack and got my own mechanical.
Offline pitashen
« Reply #1 on: Fri, 04 November 2011, 13:40:54 »
your keyboard will eventually be dented and keycaps will crack.
Offline flyball
« Reply #2 on: Fri, 04 November 2011, 13:42:05 »
nothing
[SIGPIC][/SIGPIC]
Offline Daniel Beaver
« Reply #3 on: Fri, 04 November 2011, 13:42:19 »
Quote from: pitashen;445635
Nah.
Home: Topre Realforce 87W45  /  Mionix Naos 3200
Work: Topre Realforce 87B  /  Microsoft Intellimouse Explorer 3.0
  • I <3 60%
« Reply #4 on: Fri, 04 November 2011, 13:42:40 »
That was my initial though. but still. That was to take quite a while for that to happen.
Offline elbowglue
« Reply #5 on: Fri, 04 November 2011, 13:45:11 »
When you bottom with cherry switches you're at a point with more force return, so your fingers spring up after the keystroke.  So it makes you type faster imho.  Also makes typing easier on your fingers. (requires less effort in the rebound part of the keystroke)
On the other hand, if you are bottoming out against a metal plate (plate mounted cherry) it might feel a little jarring on your fingers.
Sometimes if you have a very light touch you might be able to type faster without bottoming out. I have not found that to be the case however.
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline pitashen
« Reply #6 on: Fri, 04 November 2011, 13:45:38 »
you will even crack the casing.
Offline flyball
« Reply #7 on: Fri, 04 November 2011, 13:47:02 »
Quote from: elbowglue;445641
it doesnt work that way
[SIGPIC][/SIGPIC]
Offline elbowglue
« Reply #8 on: Fri, 04 November 2011, 13:47:47 »
Quote from: flyball;445644
thanks.  Please explain how it works. :)
Offline pitashen
« Reply #9 on: Fri, 04 November 2011, 13:50:10 »
on a serious note, just type whatever way you want.
I don't get why do people get so caught up with others' "personal opinions" on keyboards. It reminds me of the PINGS. First time buyers would get freaked out over those meaningless discussions of PING horror stories and end up not knowing what to buy, coz seriously they all PING*
tragic, TRAGIC!
« Last Edit: Fri, 04 November 2011, 13:53:57 by pitashen »
  • I <3 60%
« Reply #10 on: Fri, 04 November 2011, 13:50:38 »
The keycaps dont bottom out on the PCB or metal plate. They bottom out on the switch
Offline elbowglue
« Reply #11 on: Fri, 04 November 2011, 13:54:12 »
Quote from: Lethal Squirrel;445651
Good point.  I suspect the difference in feeling may be because the switch is sitting on metal vs PCB (comparing metal mounted switches to PCB mounted switches).  It's a big difference that I find mostly relevant in cherry brown keyboards... (I don't like filco with cherry browns, I love cherry brown PCB mounted keyboards however)
Anyhow the keycap strikes the switch casing which is sitting on metal vs PCB..
Offline Kick
  • Fuego
« Reply #12 on: Fri, 04 November 2011, 14:13:15 »
Quote from: ripster;445659
If you want to pound the keyboard like a porn star that's fine too.
I don't know how you play games, but that's how I play FPSes...
Offline mmmty
  • bang! bang!
« Reply #13 on: Fri, 04 November 2011, 14:15:35 »
It's the worst thing you can do to a keyboard :yuck:
Keyboardless
Offline Zamorph
« Reply #14 on: Fri, 04 November 2011, 14:21:53 »
Quote from: ripster;445643
i recommend googling images for "bottoming out" to see why it's so bad.
On second thought you might not want to do that.......
its a trap
Offline noodles256
  • le legendary
« Reply #15 on: Fri, 04 November 2011, 14:23:10 »
the keyboard gods look down upon bottoming out
AF | Ducky YOTD |
Offline Internetlad
« Reply #16 on: Fri, 04 November 2011, 14:37:44 »
Quote from: kick;445674
i don't know how you play games, but that's how i play fpses...
****in laggy piece of ****
EDIT: Needs more caplox.
"Beep . . . Beep . . . Beep" -Sputnik I
  • I <3 60%
« Reply #17 on: Fri, 04 November 2011, 15:07:00 »
I searched "bottoming out"
Offline TacticalCoder
« Reply #18 on: Fri, 04 November 2011, 15:16:49 »
Ripster pointed out you can type in a more relaxed way (which I find more pleasant).
Some people concerned by ergonomics are even suggesting that the feedback received when you bottom out is not good for the fingers' joints and may be a source of pain and repetitive strain injuries (used as a sales argument by people selling "ergo" stuff, so can we believe them ?)
I'm not saying it's true or not: the only thing that is sure is that the huge horde of "zomg this $5 RD rocks the house and scissor switch are the nuts anyway" people we've seen lately on GH are unlikely to find the previous arguments compelling :smile:
Offline N8N
« Reply #19 on: Fri, 04 November 2011, 15:17:18 »
Serious answer: Before I started using a Model M at work, I felt like I was starting to get the beginnings of a RSI in my hands, and I attribute that to the crappy Dell RD keyboard that I was using.  My highly unscientific theory was that it was because it was starting to get all crapped up inside, so I found myself pounding on it to make sure that all my keypresses registered.  I switched to mechanical and made a deliberate effort to stop bottoming out and my hands feel much better now.  So there :)
The answer that actually popped into my head before that one: well, now, that depends on whether we're talking about typing, off-roading, or, well, you know...
Offline theferenc
« Reply #20 on: Fri, 04 November 2011, 16:32:37 »
For me at least the repeated stress of banging into the back of the keyboard on a rubber dome lead to extreme hand pain. Chicklet keyboards being among the worst offenders in this regard.
Bottom out on a mechanical, especially of the buckling spring variety, is a much softer experience, and so doesn't cause the hand pain. And it does really sound awesome, to me.
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
« Reply #21 on: Fri, 04 November 2011, 16:39:13 »
I would agree with that. Having never used a mechanical of any sort until a couple of days ago, I would say that the blues I am now typing on feel a lot more "cushioned" as I approach the point of bottoming out. It's nice that my fingers don't feel like they're slamming into a wall on the occasion that I do bottom out.
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
Offline c0rbin
« Reply #22 on: Fri, 04 November 2011, 16:43:34 »
You should be able to type faster when not bottoming out because you don't have to make the key travel as far to register.
If you can't help bottoming out the fastest switch type is probably low-travel distance scissor switches.
I like bottoming out (although I'm trying not to... its frustrating to even try though) and I'm soon going to be experimenting with reducing key travel on my Filco by using several o-rings instead of just one. Just waiting for the new material rings from WASD...
Filco Majestouch-2 Tenkeyless Cherry MX Brown w/ PBT caps and O-ring mod
Offline ZeroGraVT
« Reply #23 on: Fri, 04 November 2011, 16:56:05 »
I bottom out on the red switch but not on the brown switch.  I feel more relaxed on the red switch but that's probably because it's so light.
