Author Topic: Capacitive Keytronic Keyboard  (Read 4295 times)
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« on: Sun, 13 November 2011, 18:19:22 »
l found this old Keytronic keyboard in the garbage at work.It's model E03417XTAT. lt's got double-shot keys and interesting key switches that register a key stroke before l fully depress them, leading me to think that they're capacitive switches. Does anybody here know about capacitive keyboards from Key Tronic?
Offline kps
« Reply #1 on: Sun, 13 November 2011, 18:29:10 »
Keytronic did a lot of foam-and-foil. But don't nearly all kinds of key switch register before fully depressed?
« Reply #2 on: Sun, 13 November 2011, 18:31:08 »
You should find better things to do with your life than say dumb things on forums.
« Reply #3 on: Sun, 13 November 2011, 18:35:09 »
Quote from: kps;451413
These key switches bottom out quite hard, but l only need to press them down a tiny bit in order to register a key stroke. Sometimes, if l even rest my hand lightly on the Enter key, it'll sometimes record a key stroke.
 lt's an interesting keyboard. l'm not sure if l've ever seen anything like it. Each key's also got a separate rubber dome that sits between the keycap and the switch to provide some tactile feedback. lf l take the rubber dome out, the weight of the key cap causes the key switch to just fall down to the bottom, and the key sticks.
Maybe l'll take apart a switch on it some time to get to the bottom of this.
« Last Edit: Sun, 13 November 2011, 18:37:59 by microsoft windows »
« Reply #4 on: Sun, 13 November 2011, 18:46:46 »
Here's some photos of the keyboard.
[ Attachment Invalid Or Does Not Exist ] 31865[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 31866[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 31867[/ATTACH]
Offline kps
« Reply #5 on: Sun, 13 November 2011, 19:38:06 »
Quote from: microsoft windows;451417
Ah, well, since you've stumped The Number One Keyboard Expert On The Planet™ — and since I have a keyboard with the same switches — I'll save you the trouble. It is a capacitive foam-and-foil.
Offline megnin
  • Topre, or not Topre? That is the question.
« Reply #6 on: Sun, 12 February 2012, 08:22:42 »
I found this topic and thought I'd add some pics of a Key Tronic I got a few years ago and the original DAS Keyboard.  They appear to be identical and both have what I assume are capacitive foam-and-foil switches.  The keys on both are also "ergo weighted" from 35 grams to 80 grams.
http://www.computermart.com/e03600qlps2.htm
Force levels used on KeyTronicEMS keyboards with Ergo Technology.
Ref:  http://www.freeopenbook.com/upgrading-repairing-pc/ch18lev1sec2.html
[ Attachment Invalid Or Does Not Exist ] 40222[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 40216[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 40217[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 40218[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 40219[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 40220[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 40221[/ATTACH]
“The only difference between me and a madman is I'm not mad." -- Salvador Dali
« Reply #7 on: Sun, 12 February 2012, 10:23:26 »
Quote from: megnin;512434
(Attachment Link) 40217[/ATTACH]
No, that is a rubber dome. Good rubber dome, though. For years, I used nothing but Key Tronic rubber domes -- nothing else compared.
Quote from: microsoft windows;451422
(Attachment Link) 31865[/ATTACH] (Attachment Link) 31866[/ATTACH] (Attachment Link) 31867[/ATTACH]
Except for the national layout, that looks precisely like a KeyTronic that I have, which I have taken apart and confirmed having capacitative foam-and-foil switches. Mine had a quite mushy landing, though.
One silly thing that you can do is to take it apart, plug it in and type with your finger tips right on the circuit board. :-)
« Last Edit: Sun, 12 February 2012, 10:25:48 by Findecanor »
