Author Topic: Replacement for my "Microsoft Internet Keyboard"??? (what kind of switches)  (Read 4464 times)
Offline wakakaa
I have been using the "Microsoft Internet Keyboard" for nearly 10 years....
Unfortunately, it has been killed by a cup of water few days ago....
Today, I just bought Ducky 1008 (Taiwanese brand, with/ Cherry Black Switches), and i realized that i couldn't get use to it. I always have many typo. (even worst than the one in my office.....). I can't take this anymore.....
My question is:
1. Anyone know what type of switches was used in that "Microsoft Internet Keyboard"? (so i can buy a keyboard with the same switches); or
2. Any other suggestion for the replacement keyboard?
Thank you so much!
Offline Tarkoon
« Reply #1 on: Mon, 14 November 2011, 13:16:18 »
The Microsoft uses ultra cheap rubberdomes. Closest to that feeling are the Topre switches, but these keyboards are really expensive...
Offline wakakaa
« Reply #2 on: Mon, 14 November 2011, 13:19:57 »
What's the closest option if my budget is about US$100?
Ducky 1008? Blue or Brown??? (I can swap the new one, or other brands, but not refundable)
Offline Tarkoon
« Reply #3 on: Mon, 14 November 2011, 13:27:05 »
If it should be a mechanical keyboard with MX switches I would say Clears are closest to rubberdomes, but still a different feeling.
Offline wakakaa
« Reply #4 on: Mon, 14 November 2011, 13:34:53 »
Quote from: Tarkoon;451930
Tarkoon, thanks for your reply.....
So i have 2 choices right now, Topre rubberdomes AND Cherry MX Clear.....
Would you please recommend one for both switches?
Offline LaneWeaver
« Reply #5 on: Mon, 14 November 2011, 13:40:38 »
You won't find a keyboard with Topre switches for $100.
I think you should go with Cherry MX Brown, since you don't like the higher-resistance Cherry MX Black (which have the same spring as the Clears).
That, or get another rubber dome. I'd give Keytronic a go.
Filco Majestouch 2 TKL | Razer BlackWidow
Offline wakakaa
« Reply #6 on: Mon, 14 November 2011, 13:47:25 »
Quote from: LaneWeaver;451941
(Sorry, i know nothing about Keyboard Switches before i bought the stupid Ducky Black Switch)
Actually I found that Tactile is a must for me, so that i could feel what i am typing, isn't it?
1. At this point, should i go for Cherry MX Brown? or Clear? (since you suggested Clear)???
2. Also, would you please explain further on the "effect" of rubberdome? (I am not too sure if i really want it)
Offline wakakaa
« Reply #7 on: Tue, 15 November 2011, 10:06:55 »
Thank you all !!!!!
Finally, I just bought Ducky DK 9008 with Blue switches.....
Cheers!!!
Offline wakakaa
« Reply #8 on: Wed, 16 November 2011, 11:35:01 »
I've started a new post, please take a look.
http://geekhack.org/showthread.php?24011-Realforce-Deck
Offline wakakaa
« Reply #9 on: Wed, 16 November 2011, 12:24:20 »
hell yea....
