Author Topic: Need keyboard for the office!  (Read 2033 times)
Offline codek
« on: Tue, 15 November 2011, 14:04:10 »
I'm in a cubicle with many others around me.  I was looking at the cherry browns but realized, they might be still too loud for the environment.
Any suggestions?  I'm also looking to spend $150 and below.   Are there any mechanicals that are quiet?
Offline BiNiaRiS
« Reply #1 on: Tue, 15 November 2011, 14:13:52 »
You could go with a WASD with the rrubber o ring mod.
Topres are also quiet but more than $150.
PCB mounted board with browns are also quiet
Sent from my EVO
KMAC 2 w/ErgoClears
Offline dimoniy
« Reply #2 on: Tue, 15 November 2011, 14:58:35 »
Get anything and then add soft-landing pads or o-rings.
Tt eSPORTS MEKA G1 | Das S Pro Silent | Leopold FC500RR/AB
All of them full-size. I love my numpad!
Offline pitashen
« Reply #3 on: Tue, 15 November 2011, 15:00:54 »
Brown switch with O-ring
Black switch (don't bottom out)
Red switch (maybe with O-ring coz very easy to bottom out)
Or just get a scissor switch keyboard, which is not all that bad.
« Reply #4 on: Tue, 15 November 2011, 18:39:51 »
I'd say a CMstorm or leopold in Red switches with o rings should work well.
Or, wait for WASD to come out with reds, though it may be a bit overbudget, depending on what he finalizes the prices to.
Also, keep in mind that "top-out" still makes a noise.
Offline N8N
« Reply #5 on: Tue, 15 November 2011, 18:44:44 »
I'm using a Filco modded to clears with Cherry doubleshots at work and I don't think anyone realizes that it is anything special.  Well, unless they look at it and notice the RGBs.
My Choc Pro w/ Browns and WASD caps is pretty quiet too if I'm typing normally but it can set up a racket if I get on a roll and start bottoming out all over the place.
Offline Autolyze
« Reply #6 on: Tue, 15 November 2011, 19:03:10 »
Black or clear would be the easiest to type on softly, but you might need to be prepared to build some finger muscles. I've got a board with o-ringed browns for the office at the moment and it works reasonably well, although I prefer the feel without o-rings. I *might* swap it with my new Leopold with clears.
« Last Edit: Tue, 15 November 2011, 19:05:17 by Autolyze »
Offline Tony
« Reply #7 on: Tue, 15 November 2011, 22:23:05 »
I am using a Filco brown at work and people don't mind it at all. Their chatting is noisier.
For my part, I have bought a headphone
« Last Edit: Tue, 15 November 2011, 22:25:13 by Tony »
Offline codek
« Reply #8 on: Wed, 16 November 2011, 12:30:20 »
Quote from: dante;452982
I'm in a cube environment and have used browns, blues, alps, and buckling springs without much complaint; maybe a comment of "what the (quack) are you doing over there?"  I gave up buckling springs because it turned me into an Advil addict - my ears needed a break and they are too much for my family.
If I were you I'd save your money and buy a Topre.  They are so nice you won't copy and paste just so you can type more.
Which topre? I'm looking for the smallest footprint possible in all black,hhkb2?
« Last Edit: Thu, 17 November 2011, 04:53:43 by codek »
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #9 on: Wed, 16 November 2011, 12:36:09 »
I've tried every one of my keyboards in the office, but the one I prefer the most is my variable Realforce (Topre switch; switched between my 103UB and 86UB)  I now work from home, so I use my SSK primarily :)
Offline HeroZero
« Reply #10 on: Wed, 16 November 2011, 15:03:00 »
Codek, curious to know what you end up with. I bought a Deck 82 (has MX blacks) a little while ago for home use it's not too loud. Was contemplating the Deck 105-key MX blacks version for the office, though might go with a Das Silent. If you're looking for a small form factor, worth a look. You can always turn off the obnoxious LEDs.
