Author Topic: Driver for Compaq KB-9965 keyboard  (Read 4966 times)
Offline afton
« on: Wed, 16 November 2011, 20:11:21 »
Hello all,
I found this nifty old PS/2 keyboard with very good condition and I found the action is
just like the way I like it. Trouble is I can't find the driver (for Windows 7, Mac or Linux).
It's not auto-install, I've tried waiting about 5 minutes for each.
Could anyone help?
ps: yes, I have tried searching on HP website, couldn't find it
using: Filco Majestouch Tenkeyless MX Brown switch
Offline REVENGE
« Reply #1 on: Wed, 16 November 2011, 20:50:02 »
The keyboard shouldn't require drivers. If you're connecting it via PS/2, make sure you do so with the computer powered off. Otherwise, most likely a hardware problem.
Offline afton
« Reply #2 on: Wed, 16 November 2011, 22:50:42 »
Quote from: REVENGE;453687
Aha! This did the trick! Thanks :D
