Author Topic: Looking for someone who can design a plate for the DOX  (Read 3068 times)
Offline TheProfosist
  • Custom Layouts Only!
« on: Sun, 20 November 2011, 08:06:54 »
I am looking for someone who is capable of designing a plate for the new DOXs that we are making that will fit in a poker case.
Originial DOX
New DOX tutorial
We have changed the DOX a bit since the model from the tutorial, so once a someone is found we will discuss everything further on the Original DOX's discussion page.
Offline Dox
« Reply #1 on: Sun, 20 November 2011, 12:25:07 »
I think that I could do it with some good pictures and measurements of the interior of the case. I already have the position of the holes to mount the PCB  in the modded PCB layout from ishtob.
ErgoDox x2 | DoxKB x2 |   IBM SSK   | HHKB pro2
« Reply #2 on: Sun, 20 November 2011, 12:29:04 »
Quote from: Dox;456152
I dont have my cases yet as people are not wiling to part until they get the their Aluminum cases. I believe ishtob has a poker case maybe he could provide us with measurements. Also my layout is a bit different than ishtob's. I have a short left shift and a split backspace as well.
Offline Dox
« Reply #3 on: Sun, 20 November 2011, 12:35:02 »
Quote from: TheProfosist;456157
No problem with the layout modification. I'm wondering if it will be possible to have the plate supported around the keyboard and not just by the mounting holes.
« Reply #4 on: Sun, 20 November 2011, 12:49:37 »
I wouldnt know about that since I dont have a poker or its case yet.
« Reply #5 on: Mon, 02 January 2012, 02:35:54 »
I have a Poker case now so I could provide measurements though it may be best to go off the DOX or Pokers PCB measurements. A goo starting point might be the plate for the Phantom.
